  • Replies 102
Posted Images
ive got a set of purple underbody neons you can have :(
I have some neons as well. I'm never going to need them on the track.. so donate.
FYI - Gadg owns Provex. He has control over this project, and as an SAU Supporter / Sponsor he will be donating his time and workshop for this project. Therefore tools / welders aren't required. But wiring / spray paiting is something we will need.
Provex are very capable with all metalwork skills. SAU members just need to donate some parts and ideas and perhaps some time if Gadg needs.
I say we need to give it a big stereo and a mini-bar or ice box.
Cougar - I'm away on the weekend, but if anyone wants to take the Lada to get the trailer to pickup the BBQ to take to the workshop to leave for John who'll drink the scotch that lay in the house that Jack built...
Then let me know - is all yours.
* anyone not up to speed with nursery rhymes - clicky
Or even better the MetallicA song.. Click
Anyway should be ok can tow with the 3.5 cylinder gemini. Still faster and safer than the Russian Tank.
hay man can we do one night say after work not worried about a time just need to call me a tee it up other wise im talking to dad tomorro and i can find out if he will be at the factory on saterday?
A Coupe half-cut is kinda hard to work with - makes it more or less impossible to keep the rear seats, or even the roof & rear glass for that matter. That said - Cutting the C-pillars lets the rear seat area be used as a bigg-ass icebox, with it's lid sealing around where the rear quarter-glass & rear screen went.
I'm having a hard time thinking-up how to get 8-burners worth of BBQing fun into a skyline boot . . . Has anyone actually tried to get anything bigger than an overnight bag through that opening?!?!?!?! ! ! It might take a more radical mod- like attaching the taillights to the bootlid, and having the hotplate slide out??
Maybe a big square-ish plate that rises up & back from the boot, with some of those weak-ass Ceramic turbo wheels as the burner knobs?? ? ! :happy:
just so you all know, over the last 3 days we've been having our spray booth fitted. not too sure how long til it's passed for safety and operational, but i spoke to my brother in law and he said if you supply the paint, he can paint it. or even if any of you know of anyone who can paint cars etc just get them to come in and get to work :rofl:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
