My front rotors are warped and I have given myself 2 options.
Option 1
Bolt on a used brembo set from a BNR34
This is quite costly and I might have to deal with warped stock BNR34 rotors too.
Option 2
Aftermarket replacement rotors
For option 2, I have narrowed down my choices to the below:-
1) Dixcel HD
2) Dixcel HS
3) Project Mu Pure Plus 6 slit
4) Endless Straight 6
Are there any users/those in the know of the above here that can give comments/reviews?
Many thanks in advance. :)
https://www.sau.com.au/forums/topic/157640-r34-gtt-fr-rotors-replacement/
SKY 34, considered it but not too sure if it will affect the FR and RR brake bias and also whether it will clear the rims.
BHDave, thanks for the input.
Howie, as below:-
1) Dixcel HD - around Y24000
2) Dixcel HS - around Y38000
3) Project Mu Pure Plus 6 slit - around Y20000
4) Endless Straight 6 - around Y42000
The above excludes shipping from Japan.
With option 2, you have missed local DBA and RDA rotors, both makes ones to suit and a fair bit cheaper than the jp import ones. Some of those prices above are more than I paid for the car
I just bot a set of Project Mu SCR's for my GTR. The front rotors were just under $700 delivered from Perfect Run. Shipping rotors from Japan is not cheap. Not on yet so I can't tell you much about how well they work.
A lot of people run DBA 4000's. UAS has them for a bit under $500 for a pair. I know several people who recommended them but have also run across a few who have had them crack after track use.
  • 1 month later...
For starters it is risky and dangerous :( to machine the diameter of a disc down just to save a couple of dollars not to mention no warranty if they explode which i have seen happen.Has the rotor been cast for this to happen and to take the risk.
R34 GT rotors are 296mm front
R34GTT rotors are 310mm front
R34 GT-R rotors are 324mm front
DBA rotors are available for the Skyline range including the R34 GTT 310mm where as RDA do not do this particular disc.You can buy std 4000's rotors instead of there slotted if you want.
it was done by a very reputable brake buisness and they wouldn't have done it if they thought it was in any way dangerous. They did it so they carry any warranty issues, and it wasn't to save a couple of dollars it was to save a lot of money.
Edited by nsm034
Each to there own but 6mm is alot to machine a rotor down by and yes i am in the industry.
If anyone wants the correct rotor DBA do the 310mm rotor in the DBA 4000 series.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
