Hi Guys i got some parts i for R32 GTR & R33 bit and pieces in my garage just want to clean up
-TRUST TYPE R BOV $270
*R33 air con controll - $20
-RB26dett ecu wiring harness to the computer $230
*R32 center air vent $60[/color]
-R32 dash $120
-R33 GTST S2 rear seat plus 2 front seat the lots $200
*R32 door just a shell $40
-R33 GTST RH door shell $80 window $50
*-R33 GTST Rh door shell white colour no damage $80
-used 87mm N1 piston 24U still in good condition for $700
* Used JUN high beam CONROD still in perfect condition for $1300
*R33 center surround $70
*R32 GTR feul tank and pump still in tank $170 or just the pump $100
*Autometer Boost gague white face with cup $60
-R32 GTR bonnet white colour $500
-GTR gear box in working order $1000
*R32 Radiator $150
*GTR turbo a pair (got little play in it) $600
-OMONI 3 center gague for R32GTR or GTST white face with sensor and wiring $180
-R32 GTR 2 front guard no dent or scratch $400 each
*R33 GTST rear caliper and rotor 97 model $200
-Greedy pipe intake of the turbo for single turbo $200
-Trust oil catch can $50
-R32 GTR rear oil pump $200
*Tranfer case tail shaft $100
- Z32 AFM still in working condition $230 each.
*OS triple plate clutch still in preety good condition heap of meat left $1300
-SARD 75occ injector $800
*GTR starter motor $120
-RB26 alternator $100
*GTR brake master cyclinder $120
*RB26 power steering pump $150
-R32 GTR standard wing silver colour $200
*17' x 40 x 255 tire 90 percent tread on it like new $150 each i got the whole set.
R32 centre console $20
R32GTR rear cradle $250
R32 GTR complete rear brake $350
*GRID torque split control system T.S dancer. $330
*GREEDY oil remote for RB26 Dett with braided line $150
this goods can be inspect before payment.
if you need any infor pm me or leave me a post.
Edited by khmer
  • Replies 123
grill and the speedo cluster.sold.
Ronin 09 as i stated
*R33 air con controll - $50
not for R32.
sorry mate i can't read lol
free bump
oh and do you want to separate the rail? $$ - is it a genuine recaro rail?
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
