Depends what it involves man.
E.g. whether he can just use an easy out with everything still in the car, or whether all th eintake piping has to come off, turbo off, manifold off too.
Why do you care if a stud is broken? Is it leaking exhaust gas?
Yeah its leaking.Performance has dropped big time.
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938376
1000 is a bit steep. look at it this way
mechanic has approx 4-6 hours work putting on/off all components to get to it. so that would be probably $300 mark
than a thread repair guy will come to extract broken stud, $50 to $500 depending how many/what damage has been done/time spent blah blah
that materials will cost you about $200 ($120 for exhaust gasket, $45 for turbo one, $2 each stud and $2 each locknut all from nissan)
so really shouldnt be no more than $800 at most considering you dont need to pay thread repair guy $500
mine all up was $700 including parts, labour etc.. thread repair guy said he has never seen anything so bad in his life ($350 he charged) so im guessing yours aint that bad
people have done it themselves and it only cost them the gaskets plus some ezy-outs so depends really...
Edited by tek_01
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938388
Where did u get your's done at.
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938417
How confident are you in doing it yourself, thats what i did the only thing that cost me was gaskets 1 stud and to pay threadtek to come and get it out (90) and plus you can get the exhaust gasket cheaper than that and not in nissan oh and studs well $1 each and $1 for locknut, over took him 10 mins tops to get it out, the first stud is cheap, but sometimes you may brake more than one when you remove the manifold. .
$1000 is still dear as. all in all took 3 hours tops to remove and fit manifold including time of threadtek.
fun and games tho good luck
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938462
I'm gonna give it a go.Shouldnt be to hard.Where did you get your parts from?
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938485
What mechanical experience do you have?
What is the biggest thing you've done on the car? have you ever done the turbo before?
Do you have car stands? Decent trolley jack?
Good socket set and spanners? breaker bar?
24mm socket? 24mm spanner?
Once you take the turbo off, you'll need new coolant too (about $50).
Got a lock up garage?
Is it your only car? can you affor dto have the car off the road for 2 weeks?
Do you have time, or can you only work on it on the weekends?
Keep in mind part shops mostly open weekdays only.
Not doubting you in anyway, but just tryin gto make sure you understand what you're getting yourself into.
Things always take longer than you expect
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938532
I know its not gonna be a easy job.I try to do everything to myself.Work,Nissan and Auto 1 is just around the corner is a big bonus.Got all the right tools so i'm gona start on it this weekend.
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938578
Its always fun to do it yourself, I only broke one stud lucky in my case but 4 others just came out of there sockets so i still replaced them, usually the ones that brake are either ends of the manifold 3 near cyl 1 and 3 near cyl 6 WD40 always helps, and where are you located?? Also it shouldnt hurt much if you drive it around with just the one broken, just poor power and no boost if its leaking.
Also ring up your mobile thread tech that are able to drive to your house and remove it for you for a quote on "x" number of studs, Unless you have access to a right angle drill, air compressor and easy outs as these things come in handy when doing something like removing studs, Or 12v drill, stud tap, and easy outs will also do the job, but there isn't too much room either end of the manifold. You will guage what i mean when you do it yourself.
Oh dont forget to clean those metal filings away either they can be nasty. And get the tools and bits n pieces before you start it makes it alot easier as well.
The gasket, you can locate an aftermarket one for less than 100 give repco a call they may help you here.
You get many things from doing these yourself, Experience and knowledge of repair giving a sense of self achievement and also money saving.
Cheers
A
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938984
Cheers
A
I'm from (Sydney) blacktown.Yeah i like the feeling that you get when you've done something to your own car.You learn from your own mistakes right.Thanx for your replys bro.Same go's to everyone else who replyed.
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2939082
all i say is have someone handy (like a thread repair guy who can come over) to pull the studs out if you cant, that will probably be your biggest problem but apart from that should be okay if u have the tools and not too bad with your hands
and to answer your question above, i got my mobile mechanic to do the work and another mobile guy came for the threads
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2939851
I got "Action thread repairs" to come and get my broken studs out - there were 3 broken and 1 more broke getting it out. He charged less than $100 including all new studs --> AND he is also mobile so came to the workshop where i had my car stored. Just required that dump pipe and turbo was removed so he could get in there.
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2941285
Yea 1k is very expensive for exhaust manifold stud removal... the studs are like $4-$6 each... but the labour involved is what is going to hurt... but 1k... f**k you'd want them to rip out your motor and do it on the bench for that much lol...
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2941306
They were charging $98 an hour for labour.Being a well known workshop in sydney i know i'm not going back there again!
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2941393
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
