im having a few issue with getting the netgear wireless modem router working! (im not sure if its the user or hardware )
Baiscly this is what i have done.
1.plug in all cords (phone line,power,network cable)
2.turn on the modem
3.went into net and type in http://192.168.0.1
now the 1st time i did this i was able to get into the setup of the modem etc but i ended not finishing the setup and closing it..
then i went back to do the same thing and i get a totally different menu when i type http://192.168.0.1, i try resetting the modem (pressing the button on the modem) and try using the cd that comes with the modem and still no luck!
baiscly what happens is the I light flashes on the modem (tring to find my adsl connection) and the menu i get into when i type 192... takes me to a page that goes NO ADSL SERVICE DETECTED, and it wont let me get back into the setup page to type in my password and username etc
what do i do?
i have taken 3 screenshots of what happens when i type in http://192.168.0.1
(it goes in order)
Thanks Michael
Ps the Modem is a Netgear DG834G v3
I am not much help, but I say if you can't set-up a netgear router, then you can't drive the interweb! I've had billion/d-link/belkin and netgear and the netgear was by far the easiest. took all of about 1 minute in total from in the box, to running my wireless network. so with that in mind, I'd say keep reading the instructions, or ring netgear. :laugh:
I am not much help, but I say if you can't set-up a netgear router, then you can't drive the interweb! I've had billion/d-link/belkin and netgear and the netgear was by far the easiest. took all of about 1 minute in total from in the box, to running my wireless network. so with that in mind, I'd say keep reading the instructions, or ring netgear. :)
ahah!
i dont get it too... i do everything they say in the instruction 1st time i was able to get into the setup menu and now for some reason i just cant :laugh:
Why would not complete the setup?
Sounds a bit dumb to me.
Unplug it all.
Make sure there are no drivers installed on windows.
Restart your computer and try again.
Maybe consult your manual as to whether there is a way to reset the router back to factory settings.
Let us know how you go
Unplug it all.
ahaha very dumb! was in the middle of doing 2things and the modem setup was the less import of the two
hmmm
This Page will Automatically Display the NETGEAR Website if a Successful Internet Connection is Detected.
Connection time 00:00:00
Connecting to server Disconnect
Negotiation Initialize LCP.
Authentication ---
Getting IP address ---
If connnection fails, check your Login, Password, and other data.
damn i must be slow hehe
  • 3 weeks later...
abit late u fix the adsl connection yet? if not there should be a shortcut on ur desktop which will bring up the password screen, if not try reinstlling software cd... make sure all the phones / foxtel box (digital) have line filters this could disrupt the adsl causing it not to work. you could even disconnect phones and watever else on line and try running wizard hopefully the connection works. for further help try calling ur isp they will talk you through it!
Edited by rgr34
michael, if you havent got it, ring netgear
i had something similar at home, cept the 192.168.0.1 didnt even work the first time(that was what was said in teh manual)
i tried everything, gave up, rang netgear, they said ohhh, its 10.0.0.1 and the login and password is this
DOH!!!
>_<
DOH!!!
:laugh:
i think i might have to. i took the modem back and get another new one. plug it in and set it up! it work fine :rant: but then a few days later it just stop working and now it doesnt work at all again! ARRR time to ring netgear i think
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
