Hi all
After some advice on which turbo/turbo's to run
Im chasing 400 awhp on a safe tune, with boost settings at 0.7 bar low and whatevers required for 400 hp on high.
I have been looking at a set of 2560R's. Whole aim is to keep the response while providing respectable power. a set of slides would also do the job however there not rated as high so I would probobly be asking more out of the turbo and im not so sure about the journal bearings? The price difference is quite large however. I also looked at a set of N1's but 3k for second hand turbo's just doesnt do it for me.
Thanks
Ian
https://www.sau.com.au/forums/topic/159610-turbos/
ian, you'll be after a set of gt-ss. however i doubt ull want to pay for that little HKS badge, so go and have a talk to dan, he's supplying my turbo's for me.
Another thing is to go and look at the dyno thread in forced induction (its a sticky) as there's a fair few setups and figures in there.
Youll be look at ~3k for the turbo's, then u'll prolly want to change dumps while they are off, and then u need gaskets.
On a side note, give me a figure ud be willing to pay for my N1's and i'll think about it. Also i'm selling those hks dumps, and the trust front pipe.
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2963491
Im sending you a PM now shane.
Slide turbos would be good but I think the wait on them is about 2 months at this stage? Also there only rated to 300 kw so I would be close to maxing them out, unless that was 300 kw per turbo.
Shane, more info on the GT SS man?
The HKS GT-SS is the inbetween standards and the HKS 2530. From what i've seen its pretty comparable to N1's. A set of HKS GT-SS will cost you $3032.32 + tax if u get hit from nengun.
I know spilmer (thats his name on here) is running a pair on his gtr.
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2963556
I've also been looking around too Ian, decisions decisions....
a mate put some of those garret 2860R's on his 32 GTR and he's very happy, they are very responsive..
I wanted something a little bigger for my GTR but with stock internals i cant. I'm thinking about getting the Garrets too. at less than $2500 a pair brand new you can't go past em..
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2964584
Apparently a well set up to4z can come close to matching the GTSS's down low....I video evidence somewhere!
I attached some turbo rating info but I think it is a little old
Along side N1s and GTSS's I would look at Apexi AX53B70 P21s and Trust T517Zs
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2964670
is that for one or both?
Both
Yeah, price is more or less the same as the 2560's ive been looking at, and this appears to be a kit with all the gaskets etc.
2860R's would probobly be too big for me and response would suffer, but where did you find them at less then 2.5k a pair?
big single!
well how driveable do u want it.? u can have a small single with internal wastegate like some of the BeeR* cars.
but i also second 2530 or GT SS
yeah ive been thinking of going to a medium sized single rated to 450 HP or the like, however airflow may suffer as opposed to the twin setup? Bearing in mind im not chasing quater mile times, its being built to turn and be a daily so midrange is important.
thanks for the pic man, helpful. Not all the turbos im looking at are listed on there but never the less I will look into the turbos your recomending.
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2965256
BeeR uses a 3037S on their drift RB26 should make the power you want and have strong midrange..afterall that is what they chase in D1!
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2965278
ian, keep in mind if u purchase a set of turbo's from nengun, ur likely to get hit with import tax, and that will soon blow the price of the turbo's way up.
going a single would be too much hassle and money. you need new manifold, dump pipe, front pipe, intercooler piping, afm piping, water & oil lines. and then it'd be majorly defectable, caus it'd be the first thing the coppers see when they lift ur bonnet.
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2965995
well i dnt remember what they are using lol.. i just remember it was an internal gate single.. that wasnt at all that big.. and was deemed quite driveable.
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2966041
the 2560R's seem the go at this stage, bang for buck they seem to be the best bet.
Hey shane how come ur never on msn anymore?
get them from dan, he'll beat anyone's prices :D
not on msn during the day as im at the toowong office now (until may), and i'm surrounded by stiffs :)
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2966120
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
