My timing belt (Nissan) was $98
BUT the labour was $220...god knows how many hours that was, or how much they charge per hour...maybe i got ripped?? :( who knows..
If u only have to buy the belt and can do it yourself...much cheaper!
https://www.sau.com.au/forums/topic/1599-timing-belt/#findComment-32181
Sounds a pretty good price, considering they have to pull the front of the engine apart to get at the belt. All the belts need to come off, the timing cover, crank pully, fan, water pump, the CAS, and then it all needs to be put back. And they probably need to remove the radiator.
https://www.sau.com.au/forums/topic/1599-timing-belt/#findComment-32564
  • 3 weeks later...
Thanx PPls.
I am trying to do the water pump at the moment and the bottom black cam belt cover wont come off.
Thanx Blind_Elk ---
Obviously I have to pull the crank pully off.. damn.
I am going to definately do a cam belt while I'm there..
damn its such a big job.
I tell you a few spanners hammers and tools have been thrown around today. with lots of cursing..
:D
https://www.sau.com.au/forums/topic/1599-timing-belt/#findComment-43857
Yep. Adj. Cam Gears.
For My R32 because I can do both the inlet and exhaust i should pick up at least 15rwkw.
they range from $400-$600 A pair.
For the R33 Btw due to the vct you can only shove one on. Maybe 10rwkw?!?!
I am going to get the waterpump/cam belt done by some one.
its quite a big job and worth the $200.
I'm also getting Adj. Cam Gears done at the same time and am seriously looking in to fitting a set of cams at the same time.
https://www.sau.com.au/forums/topic/1599-timing-belt/#findComment-44240
Joel I was goint to do the water pump myself untill i pulled the top cam belt cover off and saw what was involved. is probably not that hard but dont like risking thinks like that. I think you need to be carefull when taking the harmonic balancer off, apparently some come off easy and some take forever, this is what tillbrook said.
https://www.sau.com.au/forums/topic/1599-timing-belt/#findComment-44242
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
