hi everyone
I have been reading the posts about oil pressure. I have a r32 gts4 and it has only got 2kg/cm3 of oil pressure when it is cold and stays the same when I rev it. checked this with a mechanical gauge. is it possible to be anything else other than the oil pump.
thanks locky
i have exactly same thing. but havent checked with mechanical. going off stock guage
car is r32 gtr
RellikZephyr
firstly don't worry too much about cold readings. do the tests when the oil is over 80 degrees. for info, a healthy 32 GTR will be just above 2kg at idle and should be around 6kg when cruising at 3000rpm.
i had a problem with my car but it wasnt the exact symptons to what you are having and it ended up being a broken oil pressure release valve in the collar. hope that helps.
where's that?
I have the exact same problem as well, am working on it at the moment but freekin everything here is closed so i can't get the fitting i need. Mine goes up to 4 on startup then hovers around 2 while driving, regardless of rpm, engine runs fine though no probs, i'm hoping when i hook up an external gauge it'll read properley then can be narrowed down to either dash gauge or sender.....
where's that?
i dont know. its what my mechanic told me.
Hi Beer Baron, what would be the reading on a healthy R33 Gtst?
it's very similar. between 1 and 2 and idle and between 4-6 at 3000rpm cruising. all at operating temp of course. in my experience the stock gauge has been fairly accurate, just very slow reacting. my defi BF moves around as fast as a tacho! the stock one just slowly creeps around.
cheers guys have decided to put a new motor in as compression all over the place and turbo is on its way out. the oil pressure still doesn't move above 2 at any rpm
hey my r34 non turbo sits at 6-7 at cold start and in normal running conditions its sitrs between 4-5..and wen the revs goes higher it hits 7max..is that normal
Ok just for you guys info. Got an external gauge hooked up today and just tested the pressure staticly neutral revving it. got the following readings:
At start approx 50psi then drops down to 22-26 at idle.
2000rpm - 43psi
3000rpm - 60psi
4000rpm - 71psi
5000-8000psi - between 70-80psi
If you want kg/cm3 divide by 14.2
Now I been told you want approx 10psi per 1000rpm and thats something to aim for with any engine of any age? now i am getting more like 20psi per 1000rpm dunno if this is just because it's under no load or its a turbo engine or what. Any ideas anyone. So guess i will be off to the nissan dealer tomorrow to try and get a new pressure sender and maybe a dash gauge if that doesn't work.
Also just for the info the oil pressure relief valve on an RB26 and I am assuming all Rb engines is on the bottom of the oil pump and its a sump of job to get to....
Yours does seem pretty high!
Especially as you rev higher, Oil pressure isn't supposed to climb that high when reving a car, that's what the relief valve controls.
I would definitely start checking it out. You might start popping seals etc.
-Josh
lol it's not high dude, infact it's pretty spot on.....5.6kg/cm3 at 8000rpm. it just seems to climb fast and then level of, I suppose thats not such a bad thing really. although it's an n1 pump so it does flow more. Will be interesting to see if it comes up with similar figures under load.
Anybody know when the relief valve opens?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
