hi everyone
I have been reading the posts about oil pressure. I have a r32 gts4 and it has only got 2kg/cm3 of oil pressure when it is cold and stays the same when I rev it. checked this with a mechanical gauge. is it possible to be anything else other than the oil pump.
thanks locky
i have exactly same thing. but havent checked with mechanical. going off stock guage
car is r32 gtr
RellikZephyr
firstly don't worry too much about cold readings. do the tests when the oil is over 80 degrees. for info, a healthy 32 GTR will be just above 2kg at idle and should be around 6kg when cruising at 3000rpm.
i had a problem with my car but it wasnt the exact symptons to what you are having and it ended up being a broken oil pressure release valve in the collar. hope that helps.
where's that?
I have the exact same problem as well, am working on it at the moment but freekin everything here is closed so i can't get the fitting i need. Mine goes up to 4 on startup then hovers around 2 while driving, regardless of rpm, engine runs fine though no probs, i'm hoping when i hook up an external gauge it'll read properley then can be narrowed down to either dash gauge or sender.....
where's that?
i dont know. its what my mechanic told me.
Hi Beer Baron, what would be the reading on a healthy R33 Gtst?
it's very similar. between 1 and 2 and idle and between 4-6 at 3000rpm cruising. all at operating temp of course. in my experience the stock gauge has been fairly accurate, just very slow reacting. my defi BF moves around as fast as a tacho! the stock one just slowly creeps around.
cheers guys have decided to put a new motor in as compression all over the place and turbo is on its way out. the oil pressure still doesn't move above 2 at any rpm
hey my r34 non turbo sits at 6-7 at cold start and in normal running conditions its sitrs between 4-5..and wen the revs goes higher it hits 7max..is that normal
Ok just for you guys info. Got an external gauge hooked up today and just tested the pressure staticly neutral revving it. got the following readings:
At start approx 50psi then drops down to 22-26 at idle.
2000rpm - 43psi
3000rpm - 60psi
4000rpm - 71psi
5000-8000psi - between 70-80psi
If you want kg/cm3 divide by 14.2
Now I been told you want approx 10psi per 1000rpm and thats something to aim for with any engine of any age? now i am getting more like 20psi per 1000rpm dunno if this is just because it's under no load or its a turbo engine or what. Any ideas anyone. So guess i will be off to the nissan dealer tomorrow to try and get a new pressure sender and maybe a dash gauge if that doesn't work.
Also just for the info the oil pressure relief valve on an RB26 and I am assuming all Rb engines is on the bottom of the oil pump and its a sump of job to get to....
Yours does seem pretty high!
Especially as you rev higher, Oil pressure isn't supposed to climb that high when reving a car, that's what the relief valve controls.
I would definitely start checking it out. You might start popping seals etc.
-Josh
lol it's not high dude, infact it's pretty spot on.....5.6kg/cm3 at 8000rpm. it just seems to climb fast and then level of, I suppose thats not such a bad thing really. although it's an n1 pump so it does flow more. Will be interesting to see if it comes up with similar figures under load.
Anybody know when the relief valve opens?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
