  • Replies 72
ok to clear this up it is near the back of the PA Hospital there is a train station within walking distance to the location. Those people catching the train just ask for the station at PA Hospital.
this may sounds stupid, is dutton park near st lucia?
No, not near St Lucia. Dutton Park is not far from Annerley. If you are driving to dinner, Annerley Road (where the restaurant is) joins Ipswich Road. There is also a map in the first post.
RSVP's updated.
Karen... i hate you
Not only do i have to buy a pressie cause its relle's birthday that week.. but i also gotta go to her dinner... then ALSO the bloody pub crawl..
AND THEN you make the dinner a place that i wanted to see the SAU crew goto..
/sigh
ill have to see if i can juggle it. :( (but put me down for +1)
lol Franky boy you can walk across that bridge at St Lucia Uni striaght to dutton park up that bigg ass hill then down the other side is ribbits... like a 15 min wlak from UQ
WOOT!!! So MANY PEOPLE!!! >_<
WOOT!!! So MANY PEOPLE!!! :blink:
i hope you are not lying coz i am seriously preparing to do that.
i have uni till 5 so it would be really easy for me.
but knowing how much you hate asians, phatboi, i think you were bullshiting. lol
Have just called to make a tentative booking for 25-30 tomorrow night @ 7pm (under the name of "SAU"). We will be inside spread over a few tables, as one large table to fit all of us is not possible.
There is also only ONE bill per table (or group in our case) and we will be having the all-you-can-eat option which is $19.90 each (drinks are extra). Hope everyone is happy with this. Please ensure you bring CASH to pay for your bill portion.
Any questions, please ask!
RSVP's updated.
Cheers,
Karen
Lol why would i Lie to you Frank? :P
ummm... its just gonna be me tonight :huh:
oh well see you guys there!! :dry:
count me in but please can i folow someone ? I have no idea where this place is at all 0_o
Shane pm me let me know if your going from your place?
if not i might have to folow someone else :P
I go past the place every day when i goto work..
Pretty easy to find.. but lemme know where you can meet to start following me.. i will be going from south side to northside then back to southside tonight
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
