A very good friend of mine has had his car keyed on four separate occasions. Really sad. He really loves that car, but now has lost his spirit and doesn't keep it clean because it has been keyed so many times. Poor guy :(
feel sorry to ur frens mate.
That suck and I bet they ahve no balls as the car wont hit back.
I heared a really good story like this on the radio a while ago. A guy had a quite expensive Mercedes Benz parked in a car park. While walking back to his car he saw a guy keying his Mercedes Benz. He walked up to him and said to the guy keying the Mercedes Benz "That's not how you do it, let me show you how its done". So he grabbed the keyer by the back of the head and proceeded to smash his head/face against the panels he keyed. A very valuable lesson was learnt.
+1 for catching them in the act and bashing them into pavement with a f**kn brick
+2
Anyone have any tips on fixing the scratch/ masking it? I'm trying to save for a bike, so don't want to get it professionally done..
Worst case scenario a black permanent marker :pirate:
a few months ago i caught a 15 year old trying to grind the front of my civic on his skate-board in front of my local, he scratched the whole front of my bonnet!! little c#nt! tony hawk junior soon found out that i could run faster than he could skate and when i grabbed that skateboard.. well you know what i did..
oh thats just nasty....
similar thing happened to me a few months back
I had a rant on another forum.. it went somthing like this
>>>>> Dear women with prams,
a pram is not an extention of your arm that is appropriate to close a car door with..
they scratch and dint delicate aluminium nissan skyline GTR doors.
thinking you may have realised this I opened my car door prior to paying your husband for the monitor I won off ebay so I could be on my way and out of your driveway and indeed your life.
because you are a fat lazy sow and couldnt be f**ked closing my door by hand while you loaded you screaming little piglets into your POS hyundai you thought I wouldnt notice or care that you damaged my car.
now I can't just take my monitor and be on my way, out of your driveway and life.
now I have to get a quote to fix the door you scratched and hold you to your (husbands) word that you will pay because you didn't know you did it.
may one of your screaming ratbag kids put the car into reverse and run you down before you f**k up peoples nice vehicles because you are an ignorant fat cow.
/end rant
who the f**k uses a pram to close doors and shit like that?
I think I chewed the inside of both cheeks out so I wouldnt throttle her there and then infront of her children.
I am so pissed off!
/goes to pub to drown in beer <<<<<
  • 1 month later...
I really feel for you mate, it annoys me how in life the disrespect others show for the hard earned property of others - take comfort in the fact that they're life consists of a shallow and unmeaningful existance with no direction :D
Edited by -R33GTS-
+2
Worst case scenario a black permanent marker :whistling:
feel sorry for you mate.
Do not use a black permanent marker!!!! worst thing ever and it looks REALLY BAD!!
id say use touch up paint
Sorry to see man....
Bit like Travolta in Pulp Fiction....he sums it up pretty good: You just dont f**k with someone elses car.
When i get my next car, i think i might have a stake out with the car parked in the street to see if anyone goes near it. At least u could catch them.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
