Hey
Ma names Dave n i drive a black 180sx catch is its gota RB20DET putting out 250RWHP :) plates 620 ISI
and the altezza tail lights make it look like a 32 at night so i hope its skyline enough for u guys n girls :laugh:
ull see me round the Springwood n Rochedale south areas
catch yas l8er
