Nick has seen my car yet there is not a little bit of him in it. Therefore his quote is invalid.
2 things:
1st thing: I didn't say it, I quoted John Mayer
2nd thing: I made the quote up so your point is invalid lol
2 things:
So you made the quote thus it is your quote even if you attributed it to someone else.
Hey people
im jordan been in and outta here readin wat people have say n loving it so helpful. Iv gotta blue 32.4, be chasing a rb25det s1 in mint condition soon if any one can.help?? Otherwise a mate n i are keen as mustard on some cruises and meets around the goldy and brissy
cheers everybody
