Nick has seen my car yet there is not a little bit of him in it. Therefore his quote is invalid.
2 things:
1st thing: I didn't say it, I quoted John Mayer
2nd thing: I made the quote up so your point is invalid lol
2 things:
So you made the quote thus it is your quote even if you attributed it to someone else.
Hey people
im jordan been in and outta here readin wat people have say n loving it so helpful. Iv gotta blue 32.4, be chasing a rb25det s1 in mint condition soon if any one can.help?? Otherwise a mate n i are keen as mustard on some cruises and meets around the goldy and brissy
cheers everybody
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
