hi all. just wondering if theres a master that doesnt have a built in proportioning valve in it.
basicly i need to let more pressure go to the rears.
ive aftermarket calipers front and rear. and the front is working to hard. i want to instal a hydrolic bias valve instead of the factory one. to evan out the brakes.
any info apreciated. cheeres
https://www.sau.com.au/forums/topic/160860-r32-gtr-brake-master-cylinder/
thats right
sweet. thanks guys. yeah theres an alloy cap over it. i thought it was a press in plug. but as i was drilling it it fell off and revieled an 8mm hex screw :whistling:
but it will have to wait while i get new front discs again! i thermaly shocked them. big massive crack down one of them from over heating. uber gay!!!
so some nice alcons are going in. and lol i dont know where id be with out my weekend job at autobarn. coz this is turning quite expencive :P
  • 3 weeks later...
cool. quick update. the valve is removable but... with no valve there fluid pisses out the tiny little breather hole thats inbetween the outlets. ive got a s15 master that im gonna chop in half to see whats going on inside lol.
Front brakes working too hard ? I think that equates to rears not working hard enough .
When I was researching master cylinders for Skylines I did read that rear line proportioning valves were set differently for Z32's and 240 SX's . It may pay you to find out what our spec S14's and S15's are using and maybe substitute one of theirs . I did see somewhere that some S15's had a 1" BMC (should have BM57 stamped on the blind end) so if its bias is different (one would imagine an S15 would have substantially different front/rear weight balance) it may be the solution .
Cheers A .
Another update , whilst ratting 1st Gen Liberty bits for the RX I found that they use a Nabco 1" BMC with either 4 or 3 outlets and they appear to be a single cylinder body ie no proportioning valve . There are also available plugs so that any unused BMC outlets can be sealed safely . In the app I'm using cars could have 3 or 4 outlets so I went 4 to cover all the bases .
These Liberty BMC's have outlets facing down and towards the offside of the bay so the horizontal ones would be the ones to plug for a two line Nissan ABS type car .
I can't be totally certain these interchange with Skyline BMS's at the booster but the mounting system looks identical .
Cheers A .
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
