hi all. just wondering if theres a master that doesnt have a built in proportioning valve in it.
basicly i need to let more pressure go to the rears.
ive aftermarket calipers front and rear. and the front is working to hard. i want to instal a hydrolic bias valve instead of the factory one. to evan out the brakes.
any info apreciated. cheeres
https://www.sau.com.au/forums/topic/160860-r32-gtr-brake-master-cylinder/
thats right
sweet. thanks guys. yeah theres an alloy cap over it. i thought it was a press in plug. but as i was drilling it it fell off and revieled an 8mm hex screw :whistling:
but it will have to wait while i get new front discs again! i thermaly shocked them. big massive crack down one of them from over heating. uber gay!!!
so some nice alcons are going in. and lol i dont know where id be with out my weekend job at autobarn. coz this is turning quite expencive :P
  • 3 weeks later...
cool. quick update. the valve is removable but... with no valve there fluid pisses out the tiny little breather hole thats inbetween the outlets. ive got a s15 master that im gonna chop in half to see whats going on inside lol.
Front brakes working too hard ? I think that equates to rears not working hard enough .
When I was researching master cylinders for Skylines I did read that rear line proportioning valves were set differently for Z32's and 240 SX's . It may pay you to find out what our spec S14's and S15's are using and maybe substitute one of theirs . I did see somewhere that some S15's had a 1" BMC (should have BM57 stamped on the blind end) so if its bias is different (one would imagine an S15 would have substantially different front/rear weight balance) it may be the solution .
Cheers A .
Another update , whilst ratting 1st Gen Liberty bits for the RX I found that they use a Nabco 1" BMC with either 4 or 3 outlets and they appear to be a single cylinder body ie no proportioning valve . There are also available plugs so that any unused BMC outlets can be sealed safely . In the app I'm using cars could have 3 or 4 outlets so I went 4 to cover all the bases .
These Liberty BMC's have outlets facing down and towards the offside of the bay so the horizontal ones would be the ones to plug for a two line Nissan ABS type car .
I can't be totally certain these interchange with Skyline BMS's at the booster but the mounting system looks identical .
Cheers A .
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
