Hi all
Well tonight i return to my car at the train station and notice a few cars over some bogan scumbags are flogging the number plates off an old subaru wagon. It took a few seconds to realise it wasnt there car and by that point they saw me and i froze just thinking f**k, they have seen i have caught them doing it and they looked at my car. I know there number plate but they saw mine and my car so can easily come back and flog mine aswell or just vandalise it. :domokun:
Are there ways to keep your number plates safe? like special screws or something?
https://www.sau.com.au/forums/topic/161212-number-plate-theft/
i will rivet to your bracket thing if you want rob, but the allen keys are probably beyond those guys anyway. i dont think you will have any trouble, as thats when you will go to the police and say xyz, they wont draw attention to themselves tahts how crooks work
Couldn't help but read your from campbelltown....I've had my plates taken twice once in the car park at Ingleburn (woolies)
the second time from my front yard...rural west of Denham court.
It co-incided with the petrol prices.....haven't had a prob for a while...where did you see this happening??, alot of dead sh*ts out this way.
TBH as petrol prices rise the amount of theft of plates and the petrol drive off's (theft) have also gone through the roof probably 20 fold in last 2 years. I believe Neighbourhood watch had drive to hand out special screws to stop theft of plates.
plate theft is a common thing . if they are taking your plates , they arent targetting a "skyline" in general . it happenes to all different types of cars , and the reason it is done is to steal petrol. i know of some bad groups who would do the exact thing . so if your plates go missing - report it to the police , because for all you know your plates could of been in used in petrol theft or a robbery - who knows , but it does happen sadly . damn degenerates out there.
a good idea which i am thinking of doing , is bolting my plates , so that the bolt head - which is just a raw head with no fitting on it , is facing the front , and a bolt is on the back in the bar - that way no one can take it off unless they get the bar off . - bit extreme but i can access mine due to the fitment of my intercooler - little would they know. and would save your plates.
:wave:
.... or keep an eye on ur car.. park in a well lit space.
dnt u have cameras at the station wher u guys live? we do..
bloody woodridge gangs... :dry:
best to report it to the police. if u dnt ur only saying to the vandals that its fine to do it. and u dnt care..
000 <== call them
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
