Hey Guys,
I have a little problem. My front drivers side swaybar mount on the back of the wheel hub is broken clean off!!!! :pirate: WFT!!!!! :)
I have a whiteline blade adjustable swaybar with the heavy duty link kit and the kit is set to the third hole from the end of the swaybar.
Has this happened to anyone else?
I have ran both the blade adjustable front and rear bars for about a year and the Super Low King Springs for about 8 months without any issues...until now. Can this be replaced without having to replace the whole hub? Annyone?!
Nate
Hey Guys,
Nate
Happens occasionally, just weld the bracket back on.
:huh: cheers :D
So this is attached to the wheel hub and not a replacable item? So I should be able to just weld it and it will be fine?
Yep, I added some gusseting to mine, so it didn’t break again. Being a 100% race car, mine has a 27 mm front bar, spherical joints on the links and relatively soft spring rates, so it loads up the standard brackets a fair bit.
:pirate: cheers :)
:) cheers :huh:
Thanks for your help. :pirate: Now I have to hunt down a friend with a welder!
  • 12 years later...
Yes you can, I used to snap these every few track days.
I suggest running better suspension and reducing the hardness of your ARB.
I was all in for the super thick, super stiff ARBs but now have both on the softest setting however run much higher spring rates to combat body roll, pitch and also getting much better lap times.
Thanks for all that. Sounds sensible.
I might swap back to the stock sway bar for now.
Just had a brake problem, has anyone replaced this bit of hard line. Do I just take it off and get someone to pipe bend up something similar?
I think the stray sway bar link may have contacted the brake line while it’s been disconnected ..
Not only is the pedal feel worth whatever you have to pay, but you also get to get rid of 20+ year old rubber lines that are probably unsafe anyway.
But, here's the hot tip.....https://www.ebay.com.au/itm/HEL-Braided-BRAKE-Lines-Nissan-Skyline-R33-GTS-T-GTST/271573448661?hash=item3f3b09f7d5:g:1AEAAOSw-ldZaG1u
The original, and still the best.
The do have a plastic sleeve. Your choice of colour, etc etc. And they mount properly - they have the blocks needed.
I'm not recommending against GK-Tech - I use lots of their stuff. But the HEL lines are noticeably cheaper - and up until Dose sent me a picture of one that was very questionable, I had never had cause to doubt their quality. They were the first to offer ADR approved braided lines, after all.
But at least it is possible to tell if they (or any other brand) have been crimped, now that you know to look!
You can see and feel if a crimp has or hasn't been done. And if you pull really hard on the ends, they might come off if they're not crimped.
I wouldn't be too worried about such lines not getting crimped. That would have to be an exceedingly rare failure.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
