  • Replies 765
Do tell????
Its not mine thats for sure :banana:
i didnt think i mentioned ghey car in that post..... nah kidding
yeah yours will definately be one of the better cars with ultimate... the e-passaaaahge wit e-manaaaaaahge
I have been having real dramas trying to get my emu working, to the point I gave up on it, as with it fitted the car was running as rough as hell, or wouldn't run at all. This week I have found out that the AAC valve was choked up with crap and the TPS is faulty. Is it feasible that this could have caused my emu problems, working on the thought that the emu is more sensitive than the stock ecu and with a faulty sensor it could have been conflicting with the ecu?
Hey guys, for reference I've uploaded my current (incorrect?) IGN wiring, incl pics, etc.
When I 'correct' the IGN wiring, I'm hoping all will be well. If not, I'll use this doc to get back to where I was.
Ign_wiring_check___cp03.pdf
If anyone wants to comment, please do!
still not sure how/why the car is currently running, but it does!
I wish I could find another 34 GTT to compare! anyone?
Hi Trent,
Yes the adapter is installed - see pic - Ign_Adapter_and_JP8.pdf
Also, if you have 5min, can you comment on Page 3 in the pdf above. I'm really puzzled that the wiring doesn't match the EMU instructions.
Cheers
another question here, i cant get the speed limiter to go away, what i red you just choose disable under preferences i did that but it still cuts at 180km/h, is there anythiner more i need to do? ive checked the logger and the Emu gets right speed signal and all
  • 1 month later...
I will be tuning one of these tonight, can you connect a 0 - 5v output from a wideband AFR meter and log the values into the greddy emanage software like you can do with datalogit ?
Trent, can you give me some tips on how to do this if possible please?
yes, you can do it. There is a greddy a/f harness that you connect to the one of two ports on the front panel (option 1 or option2).Than you have to confiure the wideband in the vehicle menu/front panel. under option 1 or 2 there will be a drop menu with choices of accesories you can connect (greddy map sensor, wideband etc.)Choose wideband, than you can choose wideband make. If its Innovate, they have innovate data there. Choose it a you are good to go.
Hmmm. I'm not familiar with Blue one. Sorry.
Another nice option of wideband 02 on EMU is auto-tune function. You input desired AFRs, drive the car and EMU adds/subtracts right amount of fuel to achive desired afr. Not very spot on,but can help you save some time.
  • 3 weeks later...
yup and the innovate is already preprogrammed as an input on option 1 and 2. You just need to find or buy a plug which fits the front yellow sockets :)
this allows auto-tune and also killer datalogging features.... right down to viewing data in graph form and it will then highlight the relevant cells in the map..str8 off the datalog screen...makes for awesome tuning resolution. As the emanage has dual ign and fuellng maps you can actually tune in 32x32 instead of 16 by 16 :dry:
  • 3 weeks later...
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
