Hey guys,
I am keen to get a new ecu for my r34 GT-T Skyline, I was thinking of getting a Haltech Platnium Sport 1000, but I have also been looking at the cheaper option of Nistune and maybe a piggyback ecu. My maximum power figure that I would be aiming for would be 300kw eventualy. I have done a fair bit of work with standalone ecu's before, so I am tending that way. I am just looking for something that may be simpler and cheaper but will still do what i need it too, the Greddy Emanage seems to be a good option.
Thanks Joel
Nistune
  • Replies 765
Trent sent u a pm a lil while ago regarding emu/vman.
Do you have much expirence with vmanage..?
yeah, kinda pointless on alot of cars, the evos get good gains though.
Trent - by any chance has you tried E85 on a 1jz with the EMU? looking at doing it on my soarer cause we get 2 E85 servos here in the ACT this month and I have the Emanage lying around.
I still want to be able to run 98 so trying to figure out the best compromise of injectors that are big enough for upto the 300rwkw mark on E85 yet still be able to control the injectors with the EMU, The car is Auto so no chance of being able to use a real ECU :thumbsup:
yeah its fine but you MUST wire up the coolant temp sensor as its needs lots on temp comp for cold start.
Thanks, was going to use the plug in loom to save hacking up the factory loom.
Im guessing it needs a bucket load more fuel when cold over factory.
yup.
Reckon factory 2jz 440's will be enough for the standard turbo's there is a set going cheap I can get my hands on.
Thinking I really should get some big ones straight up to make sure I have enought fuel for the future.
While Im thinking of it, would rb25 injectors fit the 1jz fuel rail, the plugs are different but thats an easy fix, asking cause I have set of high flowed 25det squirters sitting in the garage.
440's will be fine on petrol, they will see more power than your stock turbos can muster up. no chance on e85 though
and how cheap is cheap? they can be had regularly for $150...
aboot $100 bucks, I was more thinking just for the mean time, but the effort involved in swapping them over and then havng to go it all over again when I up the boost means I doubt Ill grab them.
just worked it out, the 2jz 440's are only 19% larger so no go for e85 even now, need 550s minimum :P
oh well.
I still want to be able to run 98 so trying to figure out the best compromise of injectors that are big enough for upto the 300rwkw mark on E85 yet still be able to control the injectors with the EMU, The car is Auto so no chance of being able to use a real ECU :(
Wolf do a plug in for an auto soarer.
they do auto trans models.
are they preset will all the correct shift pressures and what not? if not the are no different to all other ecus.... all ecu's can run an auto if you know the solenoid switching and relevant input /outputs.
If it does thats pretty sweet, but i still wont touch them :D
They've done a fair few soarer auto's and most people are happy with how it comes pre-set. I like to take customers for a drive and customise the shifts to there driving style.
at what cost though, It wouldnt be free, and CBF spending 2K on a ECU plus 1500 to tune, then have to f**k around if the auto flares badly or shifts to early etc etc and at the cost per hour for workshop rates isnt cheap.
Cause there is no way you can program and auto box in a hour of cruising round the back streets.
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
    • haha all good, also he took it out to Luddenham last year with me, on a 30+ degree day too.  Car did not explode.
    • Open minded? Have I stumbled into Hongdae?
