  • Replies 765
You asked a question so I answered it. I shouldn't have bothered. I have an EMU in my own patrol so it's not like I'm against them. You made a statement that you can't buy a plug in ecu for an auto soarer, I was just correcting you. I won't make that mistake again.
Edited by O2 Autosports
For any one else, (not zebra, I know you don't want one) wolf do a plug in for an auto jzz30 1jz gte soarer.
p.s. when you stop making in correct statements, I'll stop posting.
hi all i am back on land of the skyline but now with r34 gtt auto i recently put on the following
e manage ultimate with ignition adaptor and set to 12v
with complete universal loom
specs are
nismo fuel pump
blitz 540cc injectors lag set to 1.02 and .60 for stock
and new roller bearing turbo unit with steel turbine
the problem i am having sometimes you can struggle to start
1 .when it start it idles fine etc but it has slight misfire once evry few seconds but revs very clean
2 . one you drive it after few minutes tcs and slip light will come on and stay on and canot switch it back on and sometimes it will stall
also how do i remove fuel cut
any help would be greatly apreciated
thanks
specs are
nismo fuel pump
thanks
has enyone used a z32 maf on auto box model r34 gtt
as i am having issues with it z32 maf is wired correctly setting change on e manage . but when it get to 3500-4000 rpm it just holds backs . but when use stock maff its ok , it feels like car does not know when to change gear etc
Trent/anyone
how do you set this c*nt up so that it switches between maps when the external switch is changed. now map 2 (for both ign and inj.) just makes the correction on top of map 1. i dont mind it doing it with fuel but need to have two different timing maps selected via the switch.
the f*ck do i do?
cheers,
Ben
Mine is setup for 98 and adds the fuel and timing for e85 with the secondary maps. Cant you just add or subtract the timing you need from the primary one? Or just dump the new map on with the laptop...
Once you go E85 you wont want to switch back anyway. :)
Once you go E85 you wont want to switch back anyway. :verymad:
its lpg, i just cant remember your map setup atm ben so i will check in the morn
yeah scotty, dual fuel. trying to set it up so that fuel 1 is as it is now, fuel 2 will have main load input as 3 bar map sensor, only to add fuel up top. so it iwll be working over the top of the primary fuel map. then going to run both ignition maps off 3 bar, but wiring in a relay to the 'external switch' on the emanage, using a signal from the lpg lockoff to swap timing maps between lpg and 98 when the fuel system swaps over.
simple in theory but i'm a nugget of a tuner lol
thanks heaps trent. worst case i'll just wire it all up and deal with it when we bring it down next :P ps: we both changed out minds, i decided keeping the td06 was a better idea, and tony caught onto liking the gt35r, so car now has a gt35r on it lol
Edited by VB-
It still amazes me how well the Ultimate lends itself to any type of install with all manner of wiring and setup.
Spoke to Trent today, he mentioned the fueling issue. Any other way around it? What about a secondary petrol injector for the top end? Real dual fuel... :P
sort of is and sort of isnt another way around it... gas system now takes an injector signal and uses that. there is a mechanical adjustment to get the gas injectors flowing the same as the petrol ones (just a restrictor on the injector itself). in reality we need a more powerful computer so we can remove the restrictors and run the gas injectors to full flow (which is a shitload more than anything else on the car will flow).
could wire them direct to emanage but there is no point as the emanage cant run two different size sets of injectors, so the gas is being held back to the same point the petrol is. mate wants to keep dual fuel, so ditching the petrol system and just running lpg isnt an option.
another option is upgrading petrol injectors to 800's and changing the restrictor on the lpg injectors to also make them '800cc', same as the petrol injectors. he has a set available to him cheap, but then there is no point doing all that JUST to push the gas further, if he was to do it, he'd wanna push the pterol tune further too, but if we went this route, with 800cc injectors, i've already told him we'd be going e85 :P but we'll need another fuel pump, better clutch etc. + his catback will probly start to become a restriction at this point, and it all gets out of control real quick.
dual fuel, E85+lpg is on the cards for the future though :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
