  • Replies 765
You asked a question so I answered it. I shouldn't have bothered. I have an EMU in my own patrol so it's not like I'm against them. You made a statement that you can't buy a plug in ecu for an auto soarer, I was just correcting you. I won't make that mistake again.
Edited by O2 Autosports
For any one else, (not zebra, I know you don't want one) wolf do a plug in for an auto jzz30 1jz gte soarer.
p.s. when you stop making in correct statements, I'll stop posting.
hi all i am back on land of the skyline but now with r34 gtt auto i recently put on the following
e manage ultimate with ignition adaptor and set to 12v
with complete universal loom
specs are
nismo fuel pump
blitz 540cc injectors lag set to 1.02 and .60 for stock
and new roller bearing turbo unit with steel turbine
the problem i am having sometimes you can struggle to start
1 .when it start it idles fine etc but it has slight misfire once evry few seconds but revs very clean
2 . one you drive it after few minutes tcs and slip light will come on and stay on and canot switch it back on and sometimes it will stall
also how do i remove fuel cut
any help would be greatly apreciated
thanks
specs are
nismo fuel pump
thanks
has enyone used a z32 maf on auto box model r34 gtt
as i am having issues with it z32 maf is wired correctly setting change on e manage . but when it get to 3500-4000 rpm it just holds backs . but when use stock maff its ok , it feels like car does not know when to change gear etc
Trent/anyone
how do you set this c*nt up so that it switches between maps when the external switch is changed. now map 2 (for both ign and inj.) just makes the correction on top of map 1. i dont mind it doing it with fuel but need to have two different timing maps selected via the switch.
the f*ck do i do?
cheers,
Ben
Mine is setup for 98 and adds the fuel and timing for e85 with the secondary maps. Cant you just add or subtract the timing you need from the primary one? Or just dump the new map on with the laptop...
Once you go E85 you wont want to switch back anyway. :)
Once you go E85 you wont want to switch back anyway. :verymad:
its lpg, i just cant remember your map setup atm ben so i will check in the morn
yeah scotty, dual fuel. trying to set it up so that fuel 1 is as it is now, fuel 2 will have main load input as 3 bar map sensor, only to add fuel up top. so it iwll be working over the top of the primary fuel map. then going to run both ignition maps off 3 bar, but wiring in a relay to the 'external switch' on the emanage, using a signal from the lpg lockoff to swap timing maps between lpg and 98 when the fuel system swaps over.
simple in theory but i'm a nugget of a tuner lol
thanks heaps trent. worst case i'll just wire it all up and deal with it when we bring it down next :P ps: we both changed out minds, i decided keeping the td06 was a better idea, and tony caught onto liking the gt35r, so car now has a gt35r on it lol
Edited by VB-
It still amazes me how well the Ultimate lends itself to any type of install with all manner of wiring and setup.
Spoke to Trent today, he mentioned the fueling issue. Any other way around it? What about a secondary petrol injector for the top end? Real dual fuel... :P
sort of is and sort of isnt another way around it... gas system now takes an injector signal and uses that. there is a mechanical adjustment to get the gas injectors flowing the same as the petrol ones (just a restrictor on the injector itself). in reality we need a more powerful computer so we can remove the restrictors and run the gas injectors to full flow (which is a shitload more than anything else on the car will flow).
could wire them direct to emanage but there is no point as the emanage cant run two different size sets of injectors, so the gas is being held back to the same point the petrol is. mate wants to keep dual fuel, so ditching the petrol system and just running lpg isnt an option.
another option is upgrading petrol injectors to 800's and changing the restrictor on the lpg injectors to also make them '800cc', same as the petrol injectors. he has a set available to him cheap, but then there is no point doing all that JUST to push the gas further, if he was to do it, he'd wanna push the pterol tune further too, but if we went this route, with 800cc injectors, i've already told him we'd be going e85 :P but we'll need another fuel pump, better clutch etc. + his catback will probly start to become a restriction at this point, and it all gets out of control real quick.
dual fuel, E85+lpg is on the cards for the future though :D
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
