Are you interested in a custom modified PFC to suit your RB20 and RB25?
336 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Ah I read that last night. Must have been half asleep.
I think the easiest way for the GTS-T is to bridge to two - cause that's how the Standard R33 Powerfc is naturally anyway. I tested mine at idle, and it was running 14.2 volts to a good ground (most likely 13.8 at its own ground)
So if we bridge the two outputs, then its does exactly what the normal FC does, and simply runs the pump flat out all day every day.
I think they do this with the GTR to prevent the pump being as loud as f**k all the time, especially when at idle.
It's a shame we can't run the lower voltage at idle for quietness, as I don't want anyones mum complaining when I have the car running and her in the back seat. (car running for the aircon)
Bridging them won't hurt anything, as they are simply 12volt outputs.
Ie: They output the same voltage. All they do is activate 2 different relays.
The first relay or output activates a circuit that delivers the pump 11 volts.
The second relay or output activates a circuit that delivers the pump 13 volts.
Since the R33 GTS-T doesn't have these two "circuts" in the boot like the GTR it wouldn't matter. It would see the combined voltage of the two outputs triggers, and simply turn the fuel pump on, and leave it on.
Because The First output turns off, and then the second one on after it, since they are bridged the relay in the boot only sees a constant "stay on" signal.
I'm sure Cubes would agree with all of this.
Where is he lol
Also, if you were REALLY worried and didn't believe me - attach a diode to each of the outputs on the ECU and THEN bridge them after the diodes.
Then the volts can't go back into the FC (even though they won't aas the FC with have Diodes and relays inside anyway to prevent this, and for normal operation)
When I mean the volts can't go back into the powerfc, I mean if one output shuts down, and the other powers up, then if bridged it can't go from one active output into a non active output. They are outputs anyway
- There will be a relay operating inside, and if the relay is off, then the volts can't go anywhere :P
Hnmmmmmm Cubes must have my mum out on a date or something.
Where is he lol
- There will be a relay operating inside, and if the relay is off, then the volts can't go anywhere :/
lol they are my emails to paul this morning
Hey Nick, hows the car running?
are you able to get good economy out of it?
Hmmm not at the moment having a bit to much fun driving it, but saying that only bout a 50km diff with all the mods.
PM use your number an next time im going to my beachouse ill give u a buzz, well catch up
just letting everyone know that I was successful in getting my GTR Powerfc to work in my RB25. I even gave it a bit of a tune. This means it will work 100% for the RB20.
Its up for sale too by the way so if you're interested, just let me know. Even if you want it just for a R32 \ R33 GTR.
I'll have my rb26 from nengun within a week or two. Its taken ~8weeks for delivery. :S
I'll be doing internal wiring mods so its a simple plug in.
I 'might' do a few for others that are in SA. Boostworkx have a datalogit that is required so tuning will be done there.
well, as I said up there - I have a perfectly good PowerFC to suit a R33\R32 GTR that I thought was a pro, and isn't.
Works perfectly, as I have been using it in my car and driving around with a light tune lol.
Its also configured to work also, and if you give me a heads up, I can load your data into it before I send it so that you can plug it in and drive to your tuner with it :thumbsup:
Just let me know everyone - I'll post a for sale thread at some stage.
Oh, and Its ready to go into an overnight bag, so you'd get it really fast :bunny:
might be interested joel, how much?
Let me get mine done first, order from nengun has taken 8 weeks so far. :thumbsup:
Fingers crossed I receive it next week.
Good thing with it being the 26fc is we can utilize your rb26 inlet air temp sensor.
well, the Powerfc and hand controller cost me $1100, and the loom $50
so $1150 plus post and its all yours \ anybody's :D I just want to get my money back.
but just remember, you need a tuner with a Datalogit or they won't be able to do it! I just spoke to cubes and I won't be able to do it from here unless I have a RB20. (I have a RB25)
If you have a RB25, thats another story. Mine *should* work and start - but I still recommend having someone with a datalogit near.
Its running my car right now though, and I will be driving to work with it tomorrow lol.
Edited by The Mafia
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
