I'm about to wrap my hks cast low mount manfold. I've got some s/s cable ties and two rolls of exhaust wrap.
What I want to know is,
1. Do you use a cable tie at the start or
2. If I wrap it back over the start will that hold OK?
https://www.sau.com.au/forums/topic/161746-wrapping-the-manifold/
Its a Tomei kit, has these s/s cable ties, but yeah, I did think hose clamps would be more permanent.
How did you start yours?
yeah I used s/s ties. You can start it but just wrappiong it hard form the top. Not to much of a big deal. Holds up well.
When i wrapped a manifold on my other car i was told to spray the wrap with high temp clear.
I just used regular cables ties and it held up perfectly
only if its hasnt been treated. Some have and some havn't. If it hasnt fibreglass goes everywhere..its very fine.
I don't know if I'd be too game to wrap a cast iron manifold, are you planning to race it (track)? There is a slight possibillity that if the wrap isn't even enough you will end up with uneven heat causing warping or cracking. Just be very carefull, or buy a rabbits foot. :D
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
