  • Replies 166
Posted Images
I am considering organising a GROUP BUY for the supply of these custom light up panels just like you guys are asking for, based on how much of a response I get.
These have ONLY the letters lighting up just as you guys are trying to do, with a stealth look in the day, giving it a stock Series 2 finish when they lights aren't on. They also would be available matched up to your cars paint colour code (the one shown is done in Series 2 Silver), with any colour LED. White is very effective as you can see, although a variety of other colours will be also available. The panel can then be wired up to come on with the headlights/parkers, or just the brakes or even just in when its the reverse lights come on.
Please PM me if your interested to get this Group Buy going.
How'd you go with painting these, is there a coat of black everywhere bar the letters and has the letters got plastic primer and a coat of white paint? will red shine through this as it looks like u used super bright white. I don't want to try if it will stuff it up that is all.
Does anyone know what is used in the clear factory ones to make them light up, as i have ordered my series1 garnish without seeing it at all, and the bloke on the phone has said it is chrome. now whether he classifies the s1 ones as chrome is another thing. If it is it would be a waist to paint it, and i will be getting chrome led lights eventually.
i got bad luck farken!. finished the painting today and all the build and shizz. just needed to get it wired in. managed to stuff it up somehow and lose functioning brake lights.
another thing, the garnish itself is shitting me. the one time i managed to get it hooked up right to the car, i light it up full of anticipation and what do i see but -K---NE!
only four out of my 16 led array work. so i had to cut off the sickaflex (man i used alot) from the back, break the loctite adhesions, remove all the blown leds and replace (thank god for that generous jaycar dude). wire it back up and connect to car. POP same four leds surviving. its like they kill the rest cos they r jealous or sumshit.
i tried replacing just the surving leds but they pop too. wtf? time for another trip to jaycar and a new approach. will try Al's circuit this time. dunno y mine didnt work. maybe the resistor isnt big enough?
on the plus side, my painting has improved slightly. although that too is far from perfect. sigh. 'nite fellas
yeah i did that, was shitting myself :) fixed it in the end :wave: its a fuse, its in the boot, its red... thats all i remember...
good luck with making it work :rofl:
I have also designed a new board that is 1) red with lights on 2)more red with brakes one and 3)blue on a switch
so its always red (whenever activated) then you can turn blue on to mix it up a bit :O can also make the blue turn OFF on brakes... nearly blew my head up designing it :wave:
If the resistor is not big enough it should blow more, i would say they are not connected into the right terminal, might be getting a short between the anode and the kathode. Test the board with a multimeter on ohms.
No doubt the factory facia has the best illumination. But i just didn't like th aqua colour on a pearl red car ;)
I am more then happy with how mine turned out :/
yeah im with ya there the bluey aqua colour goes good with the white, maybe even black and some various other colours but as for the red i reckon u've done a awesome job and it looks tidy too, good job
very interested, those bars actually look pretty nice!
Wat size LEDs are ppl using? I went to dick smiths and they only have 16'000 mcb at $4 each.
Now i would guess that 8000 would even be enough, but the silver paint over the skyline letters is in very crappy condition. So im considering painting the whole lot, but no black on the letters, only a coat of primer a coat of white and a coat of clear on the letters. Hence i believe i may need brighter LEDs. Would this show up VERY dull (through the paint)?
What the best thing to use to clean up all the silver paint?
Edited by 3340TH
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
