My car is in dire need of a tune as it's running 220km to 50L of premium.
I have a Link ECU and would like to know if anybody knows a tuner/mechanic that can help me diagnose any problems or lead me in the right direction of getting a few more k's out of my tank.
Current mods:
HKS 2530 turbo
HKS cooler
HKS cam gears
Bosch fuel pump
3" turbo back exhaust
GTR injectors
Fuel regulator
Link ECU
Would it be as simple as a tune?
Can anyone recommend a good Link tuner in Melbourne?
Any help appreciated. Petrol consumption is killing my wallet :unsure:
Edited by dan.1337
https://www.sau.com.au/forums/topic/161837-link-tuners/
AVO world eh...i might give them a call. I know there's a place in Richmond that tuned a mates car, but they also charge a fortune as he was charged somewhere in the vicinity of $500 depending on what needs to be done =|
also, the car is an r32 gts-t.
https://www.sau.com.au/forums/topic/161837-link-tuners/#findComment-3005196
If $500 is normal for a good tune which satisfies my problems, then i'm a more than willing to pay for it.
I've just heard of guys paying $200-250 for a full tune which is a lot less.
You'll find the guys with 200-250... thier car drives ok, but get in a decently tuned car with similar/identical mods and you can clearly see the difference.
People maybe your talking about were S-AFC's or something, just a basic interceptor which is around 200 to tune.
A full ECU tune is a lot more as its more invovled and results are better
https://www.sau.com.au/forums/topic/161837-link-tuners/#findComment-3005280
use raceingline in morrabin they have tuned mine for a few years and get great power out of mine.
they have the laptop dongal if you dont have it and the latest software so give them a try.
https://www.sau.com.au/forums/topic/161837-link-tuners/#findComment-3005484
