hey guys and gals i am just wondering how much would it cost to get the front and back windsreens as i need to maybe get some since my windows are being taken out and there is a 90% change of em breaking so i am going to put some money aside for the windscreens. so what will a good price be as i dont want to be riped off and where abouts could i go to get em either bran new or second hand??
thanks
gordon
https://www.sau.com.au/forums/topic/161958-r32-windscreens/
I have a small stone chip in my windscreen thanks to someone at the Serpentine cruise.... I maybe need a new one if its starts to crack.
Do 32 windscreens fit GTR and gtst or are they diff'rent (strokes) ?
I got a big chunk out of my windscreen on the very same cruise! Let me know how much to replace the screen if you get it done.
https://www.sau.com.au/forums/topic/161958-r32-windscreens/#findComment-3012699
Get them second hand, my back window had an encounter with a brick, Nissan wanted about 1K for back windscreen - don't ask about the seals (I payed about $150 2nd hand - $250 seems to be closer to the average)
I got mine off a GTST wreck( I have a GTR, they are the same despite what Nissan may say), so it can be taken off without breaking, just take care and don't force it... take note of wether you or the donor have a wiper or not.
When your putting back in just get universal seals, don't look as good but price difference is ridiculous.
Edited by infamous_t
https://www.sau.com.au/forums/topic/161958-r32-windscreens/#findComment-3016888
Windscreens O/B do the front Screen minus antenna for 200 pesos, where as Nissan want your left Kidney. I just got a Geniric front screen for WOB for 200, and then I will replace with a genuine item down the road. I went with Nissan seals, cost 500 all up, front and back... Fit and finish just looks a little better than the universal items.
If you want genuine, call steve @ Northside Nissan
Mike
https://www.sau.com.au/forums/topic/161958-r32-windscreens/#findComment-3019362
  • 3 weeks later...
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
