  • Replies 107
Ahhh...looked familiar :sorcerer:
What's happening on the induction side of things - is that a single throttle body manifold I spy?
Are we also going to MAP load sensors sir?
Hypertune Plenum and CNC'd runners and single Hypertune throttle body with 97mm butterfly.
No MAP sensors...new Z32 AFM's actually...it will work.
sooo would love to know what that set you back mate.
pm FTW!
here's a list...you work it out
BLOCK...sonic test, chemically clean, torque plate bore and hone, mill block, drill and tap for 12mm main studs
CRANK...new Nissan crankshaft, drill crankshaft to remove alloy oil plugs and tap for screw type
ENGINE...JUN pistons pins and rings, JUN conrods, JUN oil pump, JUN main studs, ARP head studs, Tomei cam cap studs, new Nissan oil squirters and bolts, TRUST "drag" head gasket, JUN metal inlet exhaust gasket kit, Nissan gasket set, Hi Octane 9 litre baffled sump.
HEAD...machine for cam lobe clearance, remove oil plugs thread and grub screw, full race port and polish, modify combustion chambers and high polish, instal bronze guides, cut 3 angle valve seats, lap valves and set heights, JUN camshafts, JUN titanium retainers, JUN valve springs, Tomei lifter buckets, Nitto stainless steel valves (1mm oversize), Mines cam cover baffle kit.
EXTRAS...full engine balance and assembly, fit front Cusco 1.5 way diff to new sump, port match all manifolds turbo's and plenum, TRUST twin entry "drag" intercooler, Hypertune race plenum, Hypertune 100mm single throttle body, NPC twin plate race clutch.
I already had the turbo's (HKS GT-RS) manifolds and dumps which have been ceramic coated from our last engine. These have only done two passes and are as good as new.
As you can see nothing has been left to chance.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
