Having my 32GTR tuned today power fc and nismo AFM'S I brought of a member on here Tuner wasted ages trying to get the Nismo's to work set as vg30's in the powerfc tryed to use the correction tables etc supplied with the meters no go running lean as even at idle is there some sorta trick to make these work, Have I just been ripped off any one got any ideas will post up some more details after I pick up the car in the morning and have a chance to chat with him a bit more.
Frustrating with all the time trying to sort the Nismo AFM's and then retune with the stockers it took all day.
Is there any easy way to test these out with a multimeter or something pretty unhappy really.
https://www.sau.com.au/forums/topic/162261-nismo-afms/
The tuner should be able to tell you in a matter of mins if the AFM's are faulty.
I dont see why it should take half a day of stuffing around to realise this (or check them)
IMO it sounds like the guy might not know what he is doing at this stage
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3013690
Half a day May have been an ever so slight exaggeration on my part, Dont have a whole lotta choice in tuners where I am living, and as I only had a quick chat with his offsider (he was trying to get the car sorted) I will reserve my judgement till I chat to him personally in the morning.
Was just trying to get a bit of imput on what may be wrong and if there is anything we have missed in the basic setup, personally thought put in correction table, tune away easy as ? Not sure?
Roughly how long do you think it should take to setup/tune a power fc from scratch? It has only the normal light bolt on mods exhaust pods(soon to be replaced with a box damnit) boost controller highflowed turbos etc.?
Edited by noone
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3013779
I wouldn't have bothered switching afm unless you were maxing the old ones. even when maxed there is still a little leeway. basically anything under about 280rwkw and I would have just stuck with the stockers. 300rwkw + and I'd change to the nismos. they may be faulty, unfortunately that is the risk when buying second hand afms.
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3013865
I have Nismo AFM's, in the box you would have got a peice of paper that shows the voltage curve diferences between the gtr, z32, and nismo AFM's.
You or your tuner will need to select the VQ30 option, and then edit the % on some voltage levels, i have a spreadsheet that shows the % settings to put in the PFC.
this is my peice of paper i got, i put the grid in, and the red lines are PFC voltage markers.
this it the spreadsheet that has the pfc % settings.
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3014496
just to note, changing the % corrections for each voltage range on the AFM option (which ever)
controls the load axis placement on the map, and not the actual voltage itself.
ie: if you dial in 80% at 1.0v you wont see 0.8v on the hand controller or under sensor sw check but on load axis it will 80% trim it to give you the final output on the load axis
just something i observed in my hunt for the load axis calculation which uses afm v * CONST / correction in the ljetro version
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3014785
it might not be the AFM, maybe your PFC. I had the same problem. I bought a new Z32 and it just kept on running lean. The guys from Bel Garage tried everything. They said this has only occured once previouly and I was the second customer.
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3015347
My understanding has always been that the Nismo 65 mm AFM’s are simply the standard GTR AFM bodies fitted with Z32 sensors. Hence the Z32 selection on the PFC AFM table is pretty damn close, in fact so close that it doesn’t affect the tuning process.
I haven’t tuned with Nismo AFM’s, but I have used standard GTR AFM bodies fitted with Z32 sensors and that’s what we did to do the tuning. It worked fine, the car ran perfectly and was as easy to tune as any other GTR with a PFC ie; simple and straight forward.
:rofl: cheers ;)
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3015442
There diferent enough to be a pain in the arse. My tuner wiped my setting out the first time he tuned it, and he had to put a heap more fuel in with the temp settings to limp it back to his shop from the dyno. I put my settings back in, and it ran fine again.
Edited by sav man
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3015468
Yeah got the car back and for the fairly stockish state I was quite happy and picked up quite a bit with the PFC and still running stock AFM's
So I dont think there is anything wrong with the PFC and I had the graph and table thingo above, thanks, the tuner was given those when I took it in to tune and said he had tried those settings with no luck?
He amits he isnt sure whats going on with them and said that with even with heaps (200%) on the injector values he still couldn't even get it to idle without being lean as. He suggests not using em anyway and going with z32's when I need em but as I just fitted an ARC induction box I really dont wanna use 80mm AFM's as I would have to modify the box and this may not be possible due to the design of the box etc.
and I really like the box :laugh:
Kinda pissed off about it all there is 1 other tuner in town who i havnt used but have heard some good stuff about might even speak to him too.
Spoke via pm to the SAU member I brought them from and he assured me they were working for him when he tested em by doing the following
"i went into the menu in the power fc that allows you to advance timing and injector values accross the whole map (these are only temporary and are wiped as soon as the car is turned off) and put in about 130% or so.By doing that the car idled at 15:1 and was rediculously rich on boost (we had a wideband sensor installed to map the afr's.) "
Being a little new to the whole PFC thing I assume that this was along the lines of what My tuner had been trying only he ended up at 200% (as I stated above though probably using the wrong terminology)and still no go?
Not sure quite what to do ????
Am I wrong in thinking they could be checked with like a multimeter etc or no?
Spose it cant hurt to go have a chat to his opposition (the other tuner) and see what he thinks but thus far these guys have done okay by me so dont wanna seem to be backstabbing or anything, its a fairly small town and word gets around you know what I mean.
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3019492
Have you tested them yet?
And why would you use Z32's? The Nismo's are the same thing, just fits the stock GTR piping.
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3019520
Can anyone confirm SydneyKid's suggestion above (not meaning to doubt ya mate) and actually tried it with nismo AFM's looking at the graph above and gestimating (I cant read Japanese) which is which meter they do look awful close.
Does going to an 80mm AFM ieZ32 make alot a difference to flow or is that only going to be an issue with monsta power that I dont have and probly wont anytime soon.
The ARC induction box is so nice though :laugh:
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3019526
Nismoid Actually not real sure HOW to test em, was thinking could try doing it temporary as quoted above from the guy I brought em off but dont have access to anythin to measure air fuel ratios?
Is there another way ie. multimeter etc. and yeah dont really wanna go Z32's thats why I brought the nismos to begin with seemed a much neater option then repipeing to suit Z32's
Edited by noone
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3019540
Okay for the help of others who like me ask questions without searching I found this thread
http://www.skylinesaustralia.com/forums/in...hl=testing++afm
Not the correct pinouts for an rb26dett ,at least I dont think
Will post them up too if I can find em, or if you know feel free to post!!
https://www.sau.com.au/forums/topic/162261-nismo-afms/#findComment-3027429
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
