  • Replies 121
  • 4 months later...
yeah rolled through a stop sign at the end.
had over 200 hours practice aswell. not fair :thumbsup:
Yeah unfortunately it all comes down to putting on a show for the tester. I think we should have driver training days as standard and base it on that. Not checking if know how to drive round the block.
Just trust me man dont drive the r32 at all costs.... i mean fair enough even if you know where the cops wont be, chances are that you will get caught... hell i got caught going to work in peak hour traffic and i was driving normally.... and the aftermath is preety much going to court and extending your extension, so just hang in there dude
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
