  • Replies 188
«Cyph3r»---->
PROJECT U
Rotor prices arnt cheap, and start at about
$320 plus postage for mild
$420 plus postage for wild
$720 plus postage for Race brakes.
All these prices are for front set of 2.
You havent exactly asked for the easiest things to be priced !!
The rest of the prices will be coming, when I find them.
Yep, I can get Volks for about $1,800 plus shipping.
Dont know how much shipping would be, but I could just organise a set and just send them, and work out the postage when they are sent if you want. They would probably be sent as 4 seperate packages.
Originally posted by supra man
Emanage and harness about $485 delivered
is that with both harnesses or just the one?
Hello there, im after Blitz Boost controllers. i wanna know about these models.. $$$ PLZ.
- SBC i-D
- SBC i-D II
- Dual SBC Spec S
- Dual SBC Spec R
Plz Email me at [email protected]
THANX ;P
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
