http://www.gtr.co.uk/
4.00am GMT :
Approximately 30 minutes ago, my home was raided by a combined operation by UK police and Interpol.
They allege that there have been numerous admissions for crimes on this forum, ranging from public speeding to reckless driving on UK and international roads. The provision of both written and video evidence has allowed them to compile, from what I have seen, a large amount of data to prosecute many members of this forum, including myself.
Our entire database and server has been confiscated at this point.
I will keep you updated, but naturally will ask you to refrain from any communication to avoid complicating this matter. Of the 11,500 members on this forum, they've asked for details of the following 458 members:
Showing Users 1 to 458 of 458
User Name
1198r
1846 GTR
323ian
Funny how it happened today :P:)
https://www.sau.com.au/forums/topic/162757-zomg-gtrcoukforum-is-in-trouble/
lol yep.. First thing I did was search for my username. :)
Your on that list shanef. lol
haha yeah, i frequent them quite alot!
i reckon that list is of the most frequent users on there, plus its only ~10am there so the owner/admin must have set that up lol
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
