Just wondering how much i would be looking to get for my 1993 series R33. (black)
Motor- (built by sub zero performance)
3L vl bottom end
high flowed and ported RB25 head
garret high flowed GT35/40 turbo, braided oil lines
sub zero plenum chamber, sub zero 90mm throttle body
pistons cp forgings, forged eagle rods and bolts
billet fuel rail, sx fuel regulator, 850 hp intake pump, 600 cc injectors
n1 oil pump, n1 water pump with billet pully
new balancer, hks head gasket
hybrid 1000hp intercooler, custom piping
arp head studs, braided fuel lines
microtech LTX12s computer
3 inch mandrel bent exhaust from turbo back
50mm wastegate
high mount manifold with customised t4 flange
NGK V groove plugs, k&n air filter,
turbosmart type 2 blow off valve
greddy polished oil catch can
adjustable cam gears, GTR timing belt
splitfire ignition coils, HKS cams
Other mods-
boost guage, HKS turbo timer
tinted windows, momo wheel and gear knob
19 inch HP rims with brand new tyres
lowered king springs, polyureathane rubber on sway bars
Currenty making 350rwhp on 11psi.
Massive $$$$$ spent. Let me know what you all think
Edited by blackjet
https://www.sau.com.au/forums/topic/162929-eoi-modded-skyline/
Yeah ill try to get some pics up soon. Has just over 100000kms, has a shaved nissan patrol clutch, the diff is from a GTR, and im not sure if the box is standard or not. The box is supposed to be from a GTR, but its only a 5 speed, were any GTR boxes 5 geared or are they all 6's.
You saying the box "MAY" be from a GTR scares me, as it shows how little you know about the mods :happy: . A std rb25 box is a pretty strong unit, said to be as strong as the 26box. I'll be 98% sure that it is a 25 box.
You saying the box "MAY" be from a GTR scares me, as it shows how little you know about the mods :P . A std rb25 box is a pretty strong unit, said to be as strong as the 26box. I'll be 98% sure that it is a 25 box.
im suprised no one picked up on the GTR rear diff. To run a rear diff you need to run GTR rear hubs as the axel splines are different.
Blackjet, did you have this car built, or did you jyst buy it already done? Why are you selling it? and when can we see photos?
Edited by Mr Kofi Ahmed
Na, most of the work was done when i bought the car. Dont get me wrong, I love the car, and I would prefer to keep it. But due to work commintments I havent had the time to drive it much lately. Also at the moment it would be more practical for me to buy a ute for work, and I also want another bike. The skyline unfortunately isnt much good as a work vehicle or to shift around a dirtbike.
GTR box's are awd....
have 2 driveshafts spinning doing a whole lot of fu*k all?
transfer case is driven by a chain belt off the output shaft of the box, you will find that you can remove the transfer case and put a plate over the output iirc.
the gearset in the 25 box is the same as what is in the z32 ect and is one of nissans better gearsets,
That is one hot Skyline, I wouldnt take under 20k. Thats a lot of mods.
I would be starting the price around the $23000 mark.
I thought it would make more power with all those mods.
Good luck with the sale.
Can you PM me on how much you payed for it and how long have you had it for, just curious as i have a very similar type of set up.
Its only on 11 lb of boost sub. That puppy would crank it up hard if he wound the boost up a few notches.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
