hmmm..interesting thought...wana photochop one for me to see how it looks?? :P
I thought it would look better with some skirts too so i fattened the sides up a bit :) when i'm bored some day i might try a bonet and decals with this front bar/pic
  • Replies 181
Posted Images
I thought it would look better with some skirts too so i fattened the sides up a bit :P when i'm bored some day i might try a bonet and decals with this front bar/pic
That looks pretty good actually! :)
I havent had any trouble too much with clearance, but if it quite a steep hill or something like that i try to go on a real big angle!
MissR34, thats coz ur car is not lowered :( or is it??
at stock height but when i was at murray bridge i went down a drive way that was quite steep and scraped underneath :rolleyes: and even going out of my mums drive way (thats not even a steep one) if im not a an angle i will scrape cause i did it once!
I thought it would look better with some skirts too so i fattened the sides up a bit :rolleyes: when i'm bored some day i might try a bonet and decals with this front bar/pic
nicely done. yeah bonnet is a good idea maybe black or part black to match the lip. and perhaps do something about the orange blinkers aswell :thumbsup:
those rims CE28's??
do 18's raise the car a little? relative to riding on 17's?
i've got 110mm clearance... have to be very careful. Angled attack is my friend :thumbsup:
helps to have a plastic injected moulded bar, as opposed to fibreglass. Mine would definitely have cracked by now.
got flex? :rolleyes:
8" and 9" respectively. More pics and info in my blog: Work Emotion XD9
Hi Bro
Nice informative Blog plus the Impul front bar so it's time to get the side & rear to match. The only way to go down any steep ram is to take the most left then turn right on full lock so once u feel you tyre touching the base level then turn left again to lift the front (fingers crossed). Im surprised by the amount of steep rams i could go through in shopping mall parking. Even huge speed hump i could steer straight (though sub-conciously will do a turn left & right also).
Anyway we all learn it somehow to drive it. Cheers!
  • 1 month later...
On the front bar .. Just jap sell them now .. also I think jet speed (wouldnt buy from them from what ive heard tho) and I think bodyform might have them too
Im concidering a top secret bar and impul or do luck back and skirts .. I might just go all do luck tho .. Im so confused.. Plenty of time while i pool cash tho ;)
Edited by DECIM8
Hey mate, i'm looking to get a Top Secret bar too...do u have more pics?
I will be taking more shots shortly, the one that is up is only taken with my mobile phone.
Once i clean the car and get the digital out i will post up more shots.
hey driftmeister, where did u get ur side skirt from ??? :) came with the car or custom made ?
Vinci68 : Sorry mate for the late reply, busy working. Anyway to your question, it is a complete Veilside kit all round. Hope to post more pics soon. Keep you posted. Cheers!
Edited by driftmeister
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
