does membership work from the time you sign up? or does everyones expire at the same time?
From when you sign up. You get a full year, but I do round them up so expiry falls either mid year or end of the year so renewals are easier.
If you join now you'll expire Dec 2012.
Just sent my payment through cant wait for the next track day!!!worship.gif how long does it usually take to get cards sent out?
Good stuff!
Getting the card really depends on how busy Shell is - just remember that the people running the club are all volunteers, with regular jobs and social lives outside the SAU community. Did you order a polo shirt too?
i transferred the money to the saunsw account yesterday and the mail is on the way for membership =] just wondering whether i'll get confirmation on when the card among with other things gets posted. Thanks!
<======. Keep an eye on your avatar at the left of your posts. Once you see the light blue "NSW Club Member" tag, you'll know your payments/application has been received and processed. From then on, you'll have access to the exclusive Members' section, as well as discounts to events, merchandise, etc.
The card and membership package will follow, but it depends on how busy Shell is before she an process it... Patience is the key!
sounds good =] thanks!
*really don't want to search 35 pages*
but i'd like to join, where is this so called membership form?
I'm 21
own a Gt-T coupe (silver)
and have big hands.
Love long drives and windy corners..
98 octane's my love drug ;) Buy me some you've got a date ;)
Cheers fellas'
e85 smells better and gives you twice as big a buzz Zach :P
here is a link to the membership faq. it has a link to the membership form and all instructions on how to process it
http://www.skylinesaustralia.com/forums/topic/365434-s-a-u-n-s-w-club-membership-faq/
  • 1 month later...
Ian, Shell is our "Grim Reaper" who has the power to cause you to expire.
* You therefore have 11 months remaining to get your house in order.
* Consider this a lenient sentence.
* She has been known to make your blackest nightmares come to life.
* She even thinks spiders are cute.
Who do i contact about my membership I want to attend the Texi event coming up but i want to get sau member rates?
I sent forms via fax and paid via Bank transfer in Dec.
PS i want SAU sticker!
Edited by Michael's R33
Hey i finally pulled my finger out after owning a skyline for almost 3 years and joined SAU NSW Membership! Faxed forms and sent direct payment to SAU account :)
Went the whole 9 yards and got 2 lots of the stickers, and a nice polo shirt! Bring on the Texi day next weekend. Im not running in this one but definately later on in the year :)
PM Shell and if nothing happens after a few days pm me with all the info and ill try and chase it up for you
  • 4 weeks later...
I've got a corolla.. Can I join?
I want to own a skyline....does that count? :)
benzor, wanting to own a skyline does not count, i know where you can buy a 2000 model skyline for $8000.00, buy and you will count. virgin white.
After 5 years i have finally joined too :action-smiley-069:
Paperwork faxed and Direct Deposit sent... Looking forward to getting back into the Skyline game!!
  • 3 weeks later...
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
