What farked up logic is that? :/
Why would they change the font between the two S's?
I agree though, it is a photoshop :D
Yes i did it.
Yes it's a photochop. :no:
Yes Fox sux
Yes Nova Sux....in fact any commercial radio station is shit. Commercial radio play what THEY want you to hear!
https://www.sau.com.au/forums/topic/163502-i-knew-it/#findComment-3034568
f**ked up logic? Well Al, FOX FM isn't going to make a billboard saying that they're a shit radio station...using their official logo which I'm sure is copyright etc.
So clearly the S being identical means it hasn't been painted on by someone with a can of red paint, but copied and pasted from another S on the board.....quite simple logic really.
https://www.sau.com.au/forums/topic/163502-i-knew-it/#findComment-3034569
Yea, but someone that is going to photoshop isn't going to use a different font "s" now is he? :D
hahaha.. what suburb is this in?
LOL damn vandals...
The argument is clearly whether or not its a photoshop, or vandalism....not whether or not its a real billboard :/
https://www.sau.com.au/forums/topic/163502-i-knew-it/#findComment-3034591
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
