But if you change your oil and filter every 5,000k's won't it be efficient enough getting something like a ryco as apposed to paying $25 for a greddy one? same concept as spark plugs isnt it?
and about them leaking it could be cos the seal around the oil filter wasn't lubricated prior to fitting.. that can happen cant it?
That all depends on how hard you drive your car, the condition of the engine and oil already, the environment your driving in, the efectiveness of your air filter, etc. I guess it comes down to what you believe the quality of the filter is like. Same goes for spark plugs, if your happy with $5 plugs on an engine that you have invested a lot of money into then thats your choice. I have used ryco filters on my old bombadore and found them OK, although you really need to compare them to something. So maybe note the engine oil colour and smell and then change to a different filter at the same interval and see if you notice a difference.
The whole thing that started the leaking ryco filter here on SAU was a few years back some of us bought an oill cooler kit.and what happened was the ryco filters had a thread that was not quite so tight fitting on the sandwich plate thread and they would leak oil.Before that i have used ryco and had no problems.
Since then i have only ever used valvoline oil filters for the nissan Z145A.if you ever go to auto-one (they only sell ryco & a generic brand)and ask for their generic oil filter to have a look at.look at the rubber seal and look at how flimsy it is.. when you get the valvoline oil filter from supercheap look at how meaty the rubber seal is.
The rubber seal needs to be that meaty so the filter when tight doesnt stop dead on the block after being tightened,thus not creating the seal and oil will leak.So meaty seal and the right thread is the way to go.dont force the thread make sure it goes on smoothly before tightening to much.you dont want a threaded oil filter thread.
Remember to smear a thin film of new oil everywhere on the new oil filters rubber seal to create an excellent seal.
This mite sound dumb :P but i was thinking if Nissan made the Genuine oil filter ( not sure of Genuine number but a Z145A ) anyway would they look at improving the design etc of that style of oil filter or would it will be the same design as when it first was made like 20 years ago rb30 days or even older not sure??? Because im sure aftermarket brands would continously look at improving design etc therfore i would think aftermarket would be a better option?? Any Ideas??
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
