If you want a set of the Teins RS for an R32 GTR then let me know. I know of a set, only there is perhaps a little risk associated with delivery. I purchased them then failed to go through with payment as the user has several names and a friend suggested i not proceed with the purchase.
I think I will pass based on that info.... :(
I have no idea what model Ben is referring to either unfortunately.
Cheers
Andrew
Edited by BBGTR
  • Replies 237
Posted Images
Cheers
Andrew
Don't worry Andrew, it will be sorted very soon... :woot:
And here's another vid of how AWD can't tame 350rwkws ...
http://sau.ferni.net/Jacksvids/Sandown25_04_07side.wmv (4.75mb)
:cool:
First time out and I had a ball... the Taxi only managed to get into the 1:32's but I am pretty happy with that as I only expected 1:35's. I am sure there is more time in a lap due to my driving and I had the wrong fluid in the brakes,, kept getting spongy after 3 laps...
All in all most fun I have had in my car to date... thanks SAU!
But at least you have a clubby to drive around :P All I have is an Express Van :P
Even more of a reason to think about it before you do it! :(
Hey Aaron, Eric told me you got some new suspension for the barge. Can I get some details? Happy with it?
Heres a couple videos from Brisby's car. The first one shows 2 laps from the super sprint. The second one shows the unfortunite spin that ended Troy's day.
http://sau.ferni.net/Brisby/sandown25Apr07...supersprint.avi (53MB)
http://sau.ferni.net/Brisby/sandown25Apr07.brisby-spin.avi (13MB)
LOL...wait until June Sandown. New suspension and brakes. I want to give the RB20 a hero's fairwell...it deserves a good death for how it has performed. So fingers crossed i get the thing tied down well enough to run the [shrugs shoudlers] "i hope it s not too much boost" and see if i can get a decent lap time before binning it again :)
LOL...wait until June Sandown. New suspension and brakes. I want to give the RB20 a hero's fairwell...it deserves a good death for how it has performed. So fingers crossed i get the thing tied down well enough to run the [shrugs shoudlers] "i hope it s not too much boost" and see if i can get a decent lap time before binning it again :D
I'm going to laugh so much if it rains in June. It's going to be the biggest let down in your life.
If tat the biggest disappointment in my lift then im doing ok :(
You have a lift in the playboy mansion! :O Man, you guys have the best toys.. :D
And Bris your efforts during that spin was crap.
Ths Stig would have spun that back around the second time and still punched out a 1:21... :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
