The fine used to be $110 and no points, but damn now $1.1K + 3 points? i dont think there will be too many P platers on the road with performance cars after the set date
That's the idea, you can thank the smack tards who do street racing in turbo vehicles and V8's for this crap. This is the government reacting to public out cry. Get used to it.
  • Replies 106
Posted Images
man ive noticed that in the past month there have been nothing but stories about street draging and stuff, and lets not forget noble maccas. ffs this is gonna be hard man, oh well 2 more years, i can do it :P
A mate of mine got killed in a Hyundai Excel. These law's won't stop the road toll. Driver training is what's needed.
I used to have a sticker on my old car, maybe I should get it reprinted. It said: Don't ban high performance cars, ban low performance drivers!
Yes but I think in this case.. you're not likely to see an Excel going 160k/hr and I think that's the difference and the narrow point of view that the govt sees it from.
Don't think I'm on the side of these new laws tho.
The majority of tossers driving around like f/tards and flying through traffic are usually in a commodore. Doesn't need to be a v8 either.
Its like if I see a skyline doing 140+ and almost running people off the road, I remember it for months because it's a rare event. However a commodore acting like a tard and going at the same speeds.. it's hard to remember one from another because it happens so frequently...
Actually utes have been the worst offenders of late.
I think the actual statistics on fatalities and make/model of car involved would be more beneficial to the public.. as opposed to the current media process of.. if its a skyline, 300zx, 180sx etc say "SKYLINE" and if its anything else put "SEDAN".
Hope that makes sense, I'm in a rush :P
just do community service if you cant pay it off lol
but still should be obeying those laws (yes they suck, but what can we do?)
Can you really do comm service if you get fined?
So say i get one of these fines, and i wont be able to pay it off, i can do comm service instead?
Or will they tell me to sell my car to pay for it :cheers:
all i can say, is its gunna "SUX" to be a "JU"
sucks to be a jew? lol
As far as I know, 1991-1993 R32's are the legal ones....1990 would probably be over the CURRENT power to weight limit, so it'd be a no....
Tare sticker on my rego says 1250kg, stock power is 158kw = 126.4kw/tonne
I remember ive read somewhere that it is under the limit, but the above calculation isnt helping and if cops go by the weight on the rego sticker...then im in trouble lol
rego sticker weights mean nothing.
According to this site;
http://nissanskyline.6te.net/GTST_spec.htm
R32 weighs 1320kg. If vicroads uses this weight the car is 119~kw/tonne.
There is a difference in weight between 89-90 and 91-93 because of the added intrusion bars in the later models. Question is, would vicroads put that much detail in measuring weights of different year.
i got a '92 gtst so im all sweet, plus i got 18" and me being 6ft 5" and weighing 100kg helps out lol :thumbsup:....
what has this got to do with the price of fish in China?
It's the FACTORY weight of the vehicle without passengers...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
