radius rods? is that a term im not familiar with or what, all of the sus on a 31 front end consists of tie rod ends, castor rods, swaybars, hubs / control arms and brakes....
But afaik no.
by radius rod he means castor rod, and no, you dont need to run the r32 one, just use the R31 rod.
cleaned out cooling system tonight, was filthy.......also hooked up water temp gauge.
Rears are on metal and need to get the rotors machined, so if anyone knows a cheap place to do so let me know, also need some bluey calipers as they wont seize with the hydro handbrake, unlike pos r31 items.
Cool car, gotta love RB20 power! Where and how much did ya pick the engine up for?
What is the best cheap coilovers out there? Trent obviously doesn't like the D2 coilovers and I've heard bad things about HSD, what about ISC?
Who are you? Scott from CSA? I'm a little bit confused.
Cars almost complete, got my vs calipers to go on rear with pads yesterday, minispool is on its way, and hydro lines / master will be purchased this weekend. (will be making our own bracket / modifying the original handbrake)
Still waiting on whiteline swaybars to arrive, fitted boost controller (turbotech) last night and goes real well......open wheeler sucks but.
I'll be out for drift school, who else from here's going out?
Little update:
Got an Xforce R33 front / dump pipe, and car will be going in to have its 3" exhaust into twin straight pipes done at aussie discount exhaust soon.
Fitting minispool this week, as well as hydro and vs rear calipers, so shes almost ready!
  • 4 months later...
-Updates- :D
Tried the 17x8 and 17x9 drifteks off my gts-x on it with 30 and 35mm bolt on's - yum.
So being equipped with an rb20det, bit more boost, fmic, exhaust, coilovers, swaybars, minispooled diff, hydro etc - she saw the track for drift school for the first time.
few vids -
http://s103.photobucket.com/albums/m137/dr...driftprac13.flv
http://s103.photobucket.com/albums/m137/dr...iftprac13-1.flv
Then she hit track again at AIR
vids-
http://s103.photobucket.com/albums/m137/dr...n0508.07014.flv
http://s103.photobucket.com/albums/m137/dr...ft_prac__ev.flv
Daytime prac -
2 vids -
http://s103.photobucket.com/albums/m137/dr...nt=P1060113.flv
http://s103.photobucket.com/albums/m137/dr...rent=Evsr31.flv
As she is now full mods consist of -
1988 R31 Skyline Exec, colour coded white, New front right / left guards, stripped interior with full CCS Bodykit and mfx front lip - converted from auto to manual rb20det silver top from an r32 - extreme hd clutch and blitz access ecu
Auto Gauge - oil temp, water temp, boost gauges
Just Jap fixed back race seat with 4 point TRS Harness
Hydraulic handbrake with rear vs calipers and slotted rotors
Minispooled 28 spline 3.8:9 ratio diff
Whiteline swaybars front / rear with new noltec bushes
3rd's productions adjustable castor rods
D2 a31 coilovers all round with s13 hubs, control arms, calipers / rotors
Full service on the engine
New battery, clamp, sandwich plate adapter for oil temp / water temp
Work stich rims 17x7.75 and 17x8.75
r33 xforce 3" dump / front with custom 3" under diff zaust
35mm and 30mm bolt on spacers
Bosch 040 fuel pump installed
Oil catch can setup
Turbotech controller on 14.7psi
Whiteline strut brace
New Avs rims 17x8 +24
17" pair of hack drift rims
Car was dyno'd recently and made 176.6rwkw on around 1bar, was impressed as it hasn't been remapped yet. This was on the Boostworx dyno.
And as she looks now -
Future mods -
Remap, 25 turbo, respray. yada yada yada.
If you actually bothered to look at all of the write up, lots n lots of work has gone into it and countless hours, but damn its worth it.
Cheers,
Ev. :P
to date - cost me $8,950.00
Edited by evsr31
man it looks tough as now, If you respray it go for something totally different for a 31... bright f**king yellow :( would look hot with the white wheels + stand out and get you noticed a bit more.
Edited by Simon-R32
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
