  • Replies 66
why has everyone gone for twins on a 'cheap' drag setup ?
go for a big single (garrett off the shelf). injectors, map sensor PFC, clutch, exhaust and ALOT of nos. i rekon you MIGHT just scrape in under 5K, with some second hand parts :)
Is that before or after you include the manifold you need, then custom dump/front pipe, custom piping/hosing oil/water lines etc etc etc etc etc.
Big squirt of gas. An ECU. open pipes and a cheap RB26 manifold with an XR6 turbo with some cheap injectors. If you can weld up the pipes yourself and get soem cheap 2nd hand slicks...then strip the hell uopt of it....maybe. But why woudl you bother when for 5k you could have a nice daily driver that runs flat 12s to high 11s ?
I will say it can't be done...just because if i say that some bugger will try to do it.
ill be the 1st to shake the hand of somebody who can acomplish this feat.
after a few broken engines and gearboxes they will agree with me...it can't be done.
It really not even worth trying. Even if you did everything yourself, even if you got all the parts you need under 5k, you'll be very lucky to get it off the line let alone make it down the quarter. Better to put in 10-15k if you can afford it and do it right rather than waste 5k doing it wrong.
Well said.
If this goes ahead, its likely the car will be f**ked in the process and the cost of then repairing it and doing the nessesary work to bring the thing back up to scratch will be huge.
Try and cut corners putting together a GTR and it WILL bite you in the ass, mark my words
It's one thing to talk about doing this to an XR6T which I presume is what is being discussed somewhere else and someone has said it can be easily done to a GTR. But there's one difference I think were all forgetting, A GTR is actually a good/rare car and ontop of that they aren't produced anymore, anyone who even thinks about butchering one just to prove a point is retarded. I'm happy for you to try it with an XR6T cos their becoming more popular than vl's and their still rolling of the production line, hell you could probably get most of the required parts at my local supermarket......
it will not
it will fail
TO4GTR has run an 11.2@121mph still using his original 210,000km+ engine with around 310rwkw. And he doesn't baby it at all :) Must be a freak engine.
I pesonally don't think it can be done for under 5k. Under 10k is very possible though.
I love all the expert replies from so many people that have ran 10's, according to my cousin all his mates cars run tens its easy
hahaha fools run the times consistantly then tell us how easy it is
consistancy aye buster, that why you've got an auto? :)
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
