I currently drive a Subaru WRX 99 Model which i love to death however I have discovered the hard and expensive way that the gearboxes are complete crap even when running a stock clutch. I replaced the gearbox the day after I bought it ($3500) and now my new gearbox has just died after letting a friend drive
Im thinking of selling up and moving over to a Skyline or something Nissan.
Can anyone tell me if Skylines have any renound weaknesses? Do they have strong manual transmissions?
Has anyone driven a Subaru and a Skyline?
https://www.sau.com.au/forums/topic/164695-skyline-weaknesses/
I had a 2001 WRX bugeye,definite problems with clutches(I had heavy duty),for a performance car worst seats Ive ever
sat in,some people say I went backwards when I bought a R33 Series 2 auto,that was my choice and Im extremely happy,excellent ride,no turbo lag like the WRX,excellent engine to work on,plenty of room under the bonnet,and the added bonus is I havent had any unwanted attention from the boys in blue(followed home a few time by undercover cops when I had the wrx,maybe something to do with ram raids in my area ).Photo of WRX attached
Thanks for that!
With my budget I think im gonna see if I can find an R33 GTR for around 25K...Is this possible?
I like the idea of a twin turbo. I hear the R33 GTR has a kick arse bottom end, how is the stock diff and bottom end, if i want to one day make 300rwkw?
I want to drive a weapon!
Would be wary of an R33 GTR for $25k... Stock diff is very strong, bottom end is good unless you're planning on circuit racing with sticky tyres, start running into oil control problems. Have a look for Sydneykid's oil control thread for more info on that.
Just do a search under "common problem" and you'll uncover other things
I disagree with that!! In my (limited) experience with Nissan imports (n/a 2L silvia, turbo 2L silvia, turbo s2 stagea) there have been no "common problems". Almost every problem I've encountered has either been a failure that can happen to any car (and does) or a maintenance issue.
However maybe if you do a search for 'common problem' you'll find that there really aren't any.
Skylines aren't perfect, everyone knows they have some weaknesses, but at least in stock form they have proven to be generally a rock solid performance car. They also have loads of performance potential with a lot of easily available upgrade parts.
Reliability for a modified skyline has a lot to do with how realistic you are about your power goals and how much money you are willing to invest in quality parts, and supporting mods.
At the very least you'll find that Nissan gearboxes are generally quite strong. :3some:
However there will always be a few exceptions to every rule.
well ok, i think you guys are a bit biast, so am I.
The gearbox are dam strong, but synchros suck.
Stock clutch will need an upgrade at 200 rwKw.
The S2 Turbo i find is great, it has lived at 15 psi for ages, and no issues, pulled 217 rwKw. It's all in the tunning.
THEY GUZZLE FUEL, i have been in 5 different ones, and they all eat fuel.
Unless you can do a lot of things yourself, they will be expensive for others to fix, they tend to have expensive genuine compopnents, so unless you do the leg work yourself, your up for big bucks.
EXHAUST MANIFOLD, i have not found a skyline yet, that has not had number 1 and 6 manifold snapped off.
S1 Interior scratches up SOOOOOOOOO easily.
The carpets will get holes in then in a day if cheep carpet matts are used
Other then that, these cars ar up to 13 years old, so thta means that all will have some issues. BUT buy wise and you will be ok.
Agreed on the exhaust manifold its just so common. I wonder if its poor build quality. I have asked a few supra owners, and they have no idea what im on about, as they have not have such problems . Oh, and faulty gauges too sometimes.. Really makes me wonder the quality build on Nissans
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
