Simonsen and White both had an Off in one of the stages today.
Thursday, 19 April, 2007 12.57PM
902 - Simonsen / Searcy - Off on TS13 Weldborough Pass - 8.4km - crew are OK
934 - White / White - Off on TS13 Weldbourgh Pass - 11.2km - crew are OK
Jeff getting faster in the Evo according to what results are available.
The Skelta is also out with mechanical dramas.
I have a gripe though.... BOOO to the Targa Tasmania website for not having bigger pictures available on the website.
This is the best I can get of Jeff in action.
Results page down whilst they do some work on it.
Current feelings from Jeff is that the car isn't as fast for him as the GTR.
Current placings as far as I can work out from non-confirmed times this afternoon is about 14th.
More when the results come in.
IT WAS FANTASTIC!! :)
Three more days to go!! ;)
That's all i've got time for, nice update Pete!
You suck!! :P
What kind of post is that! :laughing-smiley-014:
How about a quick run down of how you are doing for all us minions back here in Melbourne! :(
Glad you are enjoying it and well done on the Hulk!
Okay report.
Jeff and 3 or 4 other Evos broke their front diffs on the same jump today.
Apparently one wheel lands on the dirt, one on the tarmac, and if you get a little bit of air underneath you the revs flair for a split second, at the same time the diff's lock up via the computers, and when you land, one side wants to spin, one doesn't and BANG.
So they spent the rest of the day driving on the rear diff only.
An Evo driving on its rear diff, is like a GTR trying to drive on it's front diff. Not fast....
New diff going in now and should be ready for tomorrow.
Current position, about 22nd.
BASS OUT
But isn't that what a rally car should do in a normal day's work?? - Get loads of air and cover all types of surfaces? Hmmm....
So what you ar trying to say is that when the cars talents run out all EVO drivers show why they needed and EVO in the 1st place?
Now thats funny!!!!!! :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
Oh and WRX FTW!!!! :)
Hey ppls.
Well a quick wrap up.
Jeff had the diff replaced that night and was back on track the next morning.
However, placing 60th all day Saturday didn't help his position and driving the wheels off it on Sunday was pointless.
Positions in the 30s during Sunday reflected this.
So, 23rd outright for Jeff. I think that would have been his worst result in 14 years of Targa.
I'm sure Jeff will come on SAU during this week and give a bit of a wrap up.
Well done to Jeff for not leaving the track !!!
Maybe next year he'll be back in a GTR again..........
BASS OUT
Congrats to Jeff as always :)
Just goes to show that 'teh Beable GTR can nevar lose'... esp to a Beable Evo hehe
He had a quick chat/mention about it last year, I don't see why he wouldn't this year.. otherwise we'll just have to beat it out of him :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
