All the lines except the brakes you can use compression fittings, best bet be a V8 speed shop. You can order from warehouse but they cry about it because you arnt going to a shop, then if shops find out they cry to wholesaler. VPW are decent priced for speed flow. Make sure you dont get ripped at a speed shop, in Adelaide if they dont know you it will cost you fair bit more then if they do, or you know prices from VPW etc before you go in.
i was hoping to find a warehouse type place to get a roll of the stuff
and a heap of fittings, not real keen on mass dollars for pirtek etc to
make them.
As cubes said... do you have the required tools and what not?
As you dont wanna crush the teflon inside the lines
100% correct. Try and get a mechanic mate to order the stuff from wholesaler like VPW and your set.
I would avoid http://www.afterdarkspares.com/ unless your looking to line up cam cover breathers, washer bottle lines :3some:
Cheers
M
Compression lines only require some soft spanners, as steel on alloy is a no no.
Or one of those kits for cutting through the braided hose, though the tried and tested electrical tape works for 99% of jobs.
we made up all our teflon lines ourselves with just the olive and compression fitting....works perfectly. But enzed are exxy as.
Best way ive found to cut the line is with a 1mm cut off wheel on your grinder...if you want you can tape up the point your cutting, otherwise just cut without and still no drama. The blade is so thin it cuts it nice and clean with no major spurring or mess :3some:
Turbo oil feed. Fine with compression fitting? :S
Almost worth spending the $70 from Pirtek.
speed flow teflon lines rated max pressure of 1500 psi, lucky to see 100 in oil pressure applications on your motor.
I have made 100s of thise conections, best way is with the 1mm cutting disc as stated above with the line wrapped with masking tape. Now i even use a drop saw and works well.
You must use steel spanners to assemble the fittings, the alloy ones are only for taking the fittings on and off once there in service.
Edited by GTR1993
Goto Pirtek to supply and make your turbo lines, and they'll use normal compression fittings, same as oil cooler / dry sump setups. I would be more fearful of my -10 cooler hose falling off then a -6 / -8 turbo oil supply :3some:
One off stuff, id go to Pirtek / Enzed, but if you use it a lot.. it all adds up
http://www.afterdarkspares.com/ this guy is a mate of mine his prices are the cheepest i have seen
.... agreed.. the prices ARE the lowest i have seen for AN fittings....
They dont look like Speedflows, Earls, AeroQuips :spank:
- M
  • 6 months later...
Thread revival FTW!
I'm located in Melbourne and am thinking about doing up catchcan setup wih braided lines and AN fittings. Does anyone have an idea of (roughly) what the lines and fittings might cost? If its going to be crazy prices i'll just use the tubing supplied with some of the kits.
Any ideas appreciated.
if ur doing a reasonable/big order, then www.summitracing.com is the best place to go. i've brought over 2 boxes full so far, and just putting together another order :)
Thread revival FTW!
Sure, let your mouse to the walking scampering
http://www.vpw.com.au/productgroup.asp?Cat...p;PrdGrpID=3749
http://store.summitracing.com/egnsearch.asp?N=115+400041
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
