I recently had my car tuned to V-racing 100+ Octane as i been running on it for a while now. Ben from racepace does all my tuning and he managed to get more power thru the whole range as well as a bit more top end.. I can definately tell the difference, feels more responsive and less laggy (2835 pro s) and more punchy.. The previous tune was done on BP Ultimate..
I normally fill up with V-racing on High st Ashburton on the way back from work..I had no problems with availibity until just before easter. I been to cheltenham (cnr centre dandy and warrigal rds) as well as my usual supplier in ashburton but nothing.... I been running 98octane for a couple of days without hitting boost too much..
So i asked the attendant tonight whom advised that Shell were having some problems with the mix and hence had stopped all supplies, but just had sent a new sample to be tested at their HQ??? Kinda worries me that they are having problems with the brew..
So i was just wondering if there are anyone in the industry (or not) that may have heard something?? Or anyone knows of a servo that still has supplies??
Also what is a good octane booster around these days i can mix to 98 octane fuels? I have always been sceptical towards additives, i never had good results with the turbo datsun years ago.. I still miss the days of rocking up to moorabbin airport bowser with the datto and filling straight into the tank, changing the boost from 6 to 12 psi and driving away with a smile.. :3some:
I had a quick look at the Shell site but didnt see anything related... If anyone can help with the above questions it be great :spank:
https://www.sau.com.au/forums/topic/164825-shell-v-racing/
if you cant find 100ron your best and safest bet is use the temp adjust on the hand controller and back out about 4-5 deg of ign timing
SETTING,IGN/INJ,PRESS DOWN 4 TIMES
the value should change to -4 for IGN
then you can drive around and it will dial away 4 deg off the whole map so it should be safe (well safer).
just remember that value gets reset when u power the car off so you need to set it each time as its only temporary adjust.
https://www.sau.com.au/forums/topic/164825-shell-v-racing/#findComment-3053488
I think from the way its going (i believe all shells are out).
I'd either go back for a basic touch up tune or just drive around a bit easier.
You'll soon know if the car isnt happy via the knock. But if its not angry, you wont have a problem
I wouldnt bother using any octane boosters to be honest.
https://www.sau.com.au/forums/topic/164825-shell-v-racing/#findComment-3053565
thanks for that Paul....
actually i was hoping to annoy you a little at heathcote drag day for a quick tutorial as well :3some:
https://www.sau.com.au/forums/topic/164825-shell-v-racing/#findComment-3053584
well its been over 2 weeks since using 98 octane, i tried giving it a little here and there and no ping...thats the genius of Ben i guess but i am staying off boost most of the time just to be safe..
i never been impressed with octane boosters either, was hoping maybe they had improved last 10 years but sounds like they still dont do much.. thx for the reply..
https://www.sau.com.au/forums/topic/164825-shell-v-racing/#findComment-3053598
FWIW, I've used the Nulon Pro Strength octane booster when I have had my cars down in Tassie a couple of years ago (it only had 95-octane at the time) and when I've raced them at Calder/Heathcote when its been warm and they both went well with no problems.
https://www.sau.com.au/forums/topic/164825-shell-v-racing/#findComment-3053638
i could be wrong, but if there is an outage, then any shell servos that do have the V-racing will most probably have old stock and everyone knows that v-racing looses octain rating reasonable quickly with the passage of time.
does anyone know when it will be back... maybe i will give shell a call and find out.
EDIT: so this is what they said:
As of this morning (16 April, 2007) in Melb, V-Power Racing was available in:
Doncaster East
Ferntree Gully
Latrobe Terrace
Peninsula Gateway
St Albans
Tullamarine
Westgate South
Regards
Shell Technical
https://www.sau.com.au/forums/topic/164825-shell-v-racing/#findComment-3056974
ziad i was thinking the same thing..
if there is a supply issue for weeks and some servos still have stock would that mean the old stock could be stale?????
i was told the new batch they are testing is due next week..
https://www.sau.com.au/forums/topic/164825-shell-v-racing/#findComment-3058699
pretty sure ferntree gully shell has it, right up the top of burwood hwy near autobarn
it did on Sat. filled up there, not many ppl buy from there and Vermont was out.
the whole old thing is kinda crap. My pings are under 20 with the stuff which is prob. old based on this thread.
https://www.sau.com.au/forums/topic/164825-shell-v-racing/#findComment-3058864
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
