a new paint job?
hard to say really, the amount of money you put into mods your not gonna make it back when you re-sell it. your lucky if you just break even. thats why everyone takes em off and sell them seperately. also the amount of cars now for sale already have mods so the next thing if not first for people to compare is overall condition of car and engine.
Adding performance mods won't really increase value, well, at least not in a way that'll make a profit. The money you spend on the mod will not be recovered.
The reason being that people want to buy a car that has not been thrashed..... Usually because they want to be the one to thrash it.
If you're looking at increasing the value of the car, you can either make it more pristine, or you can go the dodgy and cover up faults.
You may get the money back on highflowing the turbo, because people generally don't like ceramic turbos, and it's only about 1.5K
other than that, replacing the leather boots and tidying up the interior will add value, also any body rust that can be removed.
It's really only neatening up, not really modding.
Having said all that, it's really depending on what people are willing to pay.
a new paint job?
Only if its in the factory colour, or you strip the car down and get everything painted (and even then you won't make a profit on it since that kind of paint job is going to cost you a fortune).
Otherwise, if potential buyers find the exterior paint a different colour to the interior paint (like the door sills, engine bay, etc) they'll assume its been resprayed due to an accident repair....and there goes your resale value.
I'm just wondering what parts or modifications can add value to the car?
A history. Some people will pay well over market for a car that's been owned by someone famous or something.
Or if the car becomes a cult classic. Look at the Takumi tax on AE86s - ever since Initial D came out the price for those nuggets have skyrocketed. Same with classic cars like MGBs, or old Monaros, XY GT Falcons, etc.
Aside from that, you've got buckleys of improving resale on a vehicle.
Simple rule when it comes to cars. Any money you spend on upgrading them is essentially lost money. So unless you do all the work yourself fitting up whatever you will certainly lose money.
Best bet is to get it clean & neat. If you have to spend a few hundred dollars on panel & paint then so be it. Beyond that & fixing any glaring faults, just leave it alone. That is pretty much what the car yards do - which tells you all you need to know.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
