Hey guys, need some help, Got my GTR imported and the tryers are shagged..
It has 255/40/17 the whole way round..
Can any one tell me if the R32 can fit a 275 tyre the whole way round???
Yes the car has coilovers..
Ahh, and if any one knows any one thats doing a cheap deals on tyres ant the moment that would be great!!!1
thanks guys.. and girls!! :P
Mark
https://www.sau.com.au/forums/topic/165225-r32-gtr-275-tyre/
275 in 17 will be an extremely expensive tyre (unless you buy linglongkangwhatevah garbage). Just get 235-255 and be done with it (the 275's may buzz the guards on a lowered 32 anyway if you have lower offset wheels).
goto whatever your local tyre shop is and have a chat to them...
(don't buy whatever they try and sell you straight up)
you mentioned you had 17" rims?
the width of the rims will play a large part in what width tyre you can run
as well as the offset/s as to where the rim/tyre is positioned within the guards.
i believe 9" is the minimum wheel width for 275's.
quality of tyre is just as if not more important than width though.
if u look at what u need the car for and what u want to do with it then a tyre shop can get u started.
after that do some research on net and take a look at the sticky in susspension, braking and tyres.
good luck with it - 275's FTW :nyaanyaa:
they will be sitting outside of the guards i have 265's on the back of mine atm there to wide the rims are x10 to, i had to raise the suspension for them not to scrub, im def going back to 245's or 255's take my advice and dont do it. :nyaanyaa: i took the advice of a tyre fitter supplier, they dont have a clue.
Edited by 95SKY
depends on what you want the tyres to do.
for track i got a set of BBS wheels 18 x 8 255 all round
For street i got 19 x 10.5 Volk rims with 285 all round. Rub i bit up front prolly need to raise the ride height a bit and would be ok.
For drags i need some stock 16 x 7 GTR rims.
So basically nothing is gonna do everything well, just need to choose what there for. the 19 x 10.5 have huge dish and look sweet but really there just rice.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
