  • Replies 227
this should be awesome rain hail or shine, who cares if its raining, i dunno what peoples problems are, i think its a bit soft and stuck up if your afraid to come out when its raining and leave ur mates. if your going to be like that then stay at home you little pansies, and the rest of us will ahve an awesome time!
well thats my venting done....look forward to it, should be great to see so many people and cars!
https://www.sau.com.au/forums/topic/165561-pizza/page/9/#findComment-3127072
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
