there are ways around it!
i know of some people who have taken thier (r33 gts-t) power/weight fine to court, contested it and won!
and now that they have won once.... they can never be fined for it in their same car again!
....and I know of some people who make up stories to try and look cool.
To R31Nismoid and others, a case regarding the legalities of driving a R33 gtst has been contested in court, and has been proven by the defendant that the r33 is in fact, legal to drive on your P plates.
HOWEVER, this case unfortunately did not create precedent for others, but was argued (and won) with some of the following points:
a) How old the car is...
b) How damn close to the power/weight border it is
c) The fact the car is tuned for 105 octane petrol in japan, so those ""FACTORY"" figures are based on higher performance petrol... where as we have 98 octane, therefore performance level of a stock r33 gts-t brand new in japan vs performance of a stock r33 gts-t 14 years later in Australia are alot lower.
d) The cars REAL weight, tested at a weighbridge
The bloke now can get pulled over wherever and whenever and is legally aloud to drive a R33 GTST on his P plates.
Cost of lawyer: $750
Buying a new tie for court: $80
Driving your pride and joy LEGALLY: $Priceless
Edited by DjeMz
  • Replies 79
That's what I was saying! you're the one saying the r33 is already illegal for a p plater so can't be made legal.
if the r33 gtst was made to have less power it would be NO LONGER OVER THE POWER TO WEIGHT LAWS.
you REALLY need to work on your comprehension skills.
as for the costs involved, they are irrelevant at the moment. we're discussing all the ways a p plater can legally drive a r33
How are costs irrelevant?
I will chase it up and let you all know.
Thanks :laugh:
I wouldnt mind checking it all out. I love beating the law thats for sure :)
if you could find that case it would be awesome. id pay double that if i could drive my car legally. off the top of your head, why didnt it set a precedent? i thought any case can be used as a precedent because its up to the second judge to decide if its relevant (yr 10 legal studies talking). and how did he end up in court in the first place? before or after getting dicked?
Precedents can only be set in a higher court.
That would have been heard in the Magistrates court where that cant occur
Not necessarily, the Magistrate could have suggested the case be sent up to a higher court, however over a simple traffic related matter, I don't thing he or she would bother, nor the defendant have the time or resources (to afford a high court lawyer when he/she drives a r33 :D ) to argue much a matter.
The issue MIGHT HAVE (again still trying to chase down the facts) got sent to court after the defendant did not pay the fine and received a court summons to explain why the fine has not been paid or/and the defendant chose to take the matter to court.
Mate there's no need to be such a prick about it.
No one said anything about using sandbags. I was thinking along the lines of adding corner weights.
And for your information:
Straight from http://www.arrivealive.vic.gov.au/c_youngGLS_9b.html
Now who's wrong?
Ass is right, (AGAIN :blink:) The weight is always a factory figure, modifications only refer to increases in power, which again works against you.
Your only option is to upgrade to an r32/r31 etc :w00t:
To get a car Enginereed cost hundreds, if not thousands of dollars.
To get a car ADR Approved (EPA Etc), you can be looking at upwards of $50,000.
It is so unfeasible it is impossible.
This hurts my head. Every post just gets more and more idiotic.
Edited by Mulkers
I'm probably wrong here... but i thought the new laws didnt affect those already on their P's, they just remained on the old system? Maybe im wrong here..? I should be safe enough with my lil 32 tho..!
http://www.skylinesaustralia.com/forums/in...p;#entry3044704
Removing the turbo doesnt constitute having a non-turbo car.
Fact of the matter is its still a R33 GTS-t by the build plate, and EPA to boot.
mkay, now had you actually read what my post was about, you would've read that it was not about making it a non-turbo car in form of registration, but lowering the power to weight ratio in order to make it legal for pre june 30th 2007 p-platers.
from the vic roads site
"If your car is modified, you may also need to obtain an engineer's certificate and do your own calculations. You are also required to notify VicRoads of any significant modification. Penalties for not doing so are tough."
go flame me again im just trying to explain how we do it for the victorians
Edited by lexi bro!
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
