paul,
I know someone who is selling a direct port, efi setup. Find out how much for you?
Also NOS has a new Noszil system. It basically goes in as a new 'seat' for the factory injectors. The seat contains the fuel and nitrous feed and is absolutely fantastic for atomisation/spray and perfect distribution per cylinder. It also makes install a walk in the park, with no tap and die set required.
  • Replies 62
  • 1 month later...
Thought I'd resurrect this thread, for those following the nitrous GTST relationship.
So far 50hp works wonders. I am using the fogger 2 nozzle system , but I will change to the 'soft plume' to allow better atomisation for more even distribution.
The other thing to look out for is the rubber join on the throttle body gets super cold. Even after a substancial drive around without the gas it remains quite cold. With variations of temp it will be interesting to see how the original rubber part holds up.
Originally posted by kidd
feel pity for whoever buys your ride and joins sau. only to find it was a guinea pig car for every form of thrashing:mad:
Kidd,
sorry mate I don't think I understand what your trying to say.. do you?
The person who buys my car will be very well informed of what I've used it for, in fact I would reccomend they check out SAU to get the feed back from people who know me and how I treat the car. I have yet to place a single add outside SAU, because I rather like the idea of people being able to gather info on my cars history to make an informed decision.
You might be interested to know that my car is quicker than most because the engine is in great condition as are all the mechanicals, and I keep it that way. I take a degree of pride in maintaining my car,and unlike some people I know what I'm doing.
As for your NOS questions....
"fit the jets" one nitrous jet (0.051 inches) and one fuel jet (0.034 inches) makes for the correct 100HP mixture.
Upping the jets actually makes more heat in the engine due to the large increase in horspower. Though the nitrous gas does cool the intake air.
NOS is dangerous and so is petrol. I recomend morons stay away from both.
I only get automotive grade NOS which contains a sulfur compound that 'stinks' and lets you know you have a leak. The bottle is stored in a ventilated and sealed boot and the intention is not to even have it present when I drive on the street.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
